| Uniden Scanners A forum for the discussion of all Uniden scanning radios and receivers. |
01-31-2013, 8:26 PM
Has Anybody Here Used 100% Of The Memory On Their BCD396XT Or BCD996XT?
As posted above, I am just wondering if anybody here has used ALL of the memory on either the BCD396XT or BCD996XT?
01-31-2013, 9:34 PM
I have 9 trunked systems 300 conventional channels 212 air channels and about 150 of random junk And I've used 17 percent.
Proud owner of a HARRIS FALCON III AN PRC-152 Multiband Radio.
01-31-2013, 10:09 PM
nope i have 53 systems, 102 sites and 5,073 channels on my scanner and i am at 15% best investment ever, if you are thinking of buying one DONT HESITATE!!
BCD396XT, BC346XT, PRO-82
Twitter: @inlandpatch
01-31-2013, 11:34 PM
I have several setups for different people, biggest one for a FPS officer has according to freescan, 9,006channels, 488 groups, 96 sites, 96 systems = 36% used
02-01-2013, 4:23 AM
Wiki Admin Emeritus
I've seen this come up when folks have a new scanner, they don't clear the pre loaded data, and do an add several times in FreeScan, rather than a replace
02-01-2013, 4:29 AM
Somebody should program whole MPSCS into theirs
That's the largest trunking system in America amirte?
K7POL
Monitoring Snohomish County Emergency Radio System.
02-01-2013, 5:00 AM
Yup I am maxed out on two BCD396XT's. I have all of my vacation destinations stored so each time I go back I can add/modify what is in there and I don't have to worry about reloading stuff. I also have a couple of systems that have entire search ranges in them which take up a few hundred slots each. Thanks to programs like freescan we don't have to enter each freq separately like the old days! Memory is so cheap these days I sometimes wonder why they don't have even more space available. I can sure use it, lol.
Bob
02-01-2013, 9:07 AM
bcd396xt. 9 systems. 9 sites. 109 ch's. memory 0 memory used.
bcd996xt. 10 systems. 11 sites. 256 ch's. 2 merory used.
but i change thing's/add/delete once in a while.
drooling is a problem that can be licked !
02-01-2013, 2:01 PM
I think it may be tied with ohio Marcs too. If these could decode TETRA I wonder what the whole AIRWAVE system in the uk would do. It would probibly kill it. That is one big system.
Edit I looked up the largest system I believe it's the Louisiana LWIN system with over 67,000 users on it.
02-02-2013, 8:22 AM
Airwave is encrypted, so programming it into your scanner would literally be a waste of memory.
Rgds,
Raccon
02-02-2013, 9:41 AM
I know that. I would only do it if I could decode it.
02-02-2013, 5:54 PM
I have two 'maxed out' loads for my XT's
About 70% is identical in each, and the other 30% is unique.
Obviously all the systems are not being scanned all the time.
Usually just 3-8 or so at any one time.
But programming that way allows me to scan any combination of systems at any time without having to reprogram.
Rich
02-02-2013, 8:45 PM
no way lol i have 7 systems 1 full 7sites channels 1178.
02-03-2013, 10:00 AM
Decoding TETRA (which is what you mentioned earlier) and decoding encryption are two different things. The former is comparably easy, the latter not so much. Although Air-Interface Encryption (AIE) is part of the TETRA standard it is optional, thus decoding TETRA does not mean you can also decode TETRA AIE.
Rgds,
Raccon
02-03-2013, 10:56 AM
Sorry for all of the confusion. Yes I know TETRA is end to end encrypted. What am saying is if TETRA was not encrypted. If they had a scanner that could decode TETRA if it was not encrypted the uk systems would be huge.
02-04-2013, 5:03 PM
On my bct15x and bcd396xt, have hundreds of freqs between them and a few trunks. that includes testing freq bank-sub..Still plenty of room.. I'd love to see the programming of a newer uniden that is filled. Gotta be something good in it..
02-05-2013, 11:53 AM
AIE is not the same as E2EE, which is also optional, i.e. TETRA can be clear, with AIE, with E2EE or both (AIE and E2EE).
I see.
Rgds,
Raccon
02-06-2013, 11:21 PM
Seņor Member
I like the fact that Freescan warns you when you've hit a limit. Short answer: yes I've maxed out my 996XT.
