Old 02-01-2013, 3:22 PM
RonnieUSA's Avatar
Default Uniden BCT15X
Just ordered one fro RadioShack while they were on sell.
I got it for $179.99 no shipping or tax charges.
My 1 question is I have one trunked system where I live, is there a way to import the talk groups I have found with my Pro-197, or will I end up doing a lot of copy, and pasting?
It is just the talk groups that I was wondering about.
I will learn to use free scan to program it with.
So I will have a new feeder radio next week.
Does this come with a programing cable, or do I need to order one?
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 02-01-2013, 3:59 PM
zl2taw's Avatar
it comes with a programming cable that has RS-232 plug
73's Doug
Kenwood R-5000 / Elad FDM-S1 SDR / Wellbrook ALA-1530 / various software decoders
Brisbane, Australia, UTC+10
Old 02-01-2013, 4:03 PM
RonnieUSA's Avatar
Great, I wasn't sure if I needed the Uniden USB-1 Scanner Radio PC Interface Cable or not.
Thank You Very Much.
Old 02-01-2013, 5:40 PM
davidmc36's Avatar
Do you have a 9 pin comm port on your computer? If so, you are fine.
If you only have USB then you need the USB-1 or a Serial-USB adapter.
No Bounce, No Play.
The one who dies with the most toys wins
Old 02-01-2013, 6:17 PM
RonnieUSA's Avatar
Yes I do.
Thank You.
But is there an easy way to copy talk groups, the rest will be easy they are analog, just 1 trunked system.
AdamDaMan's Avatar
You also don't HAVE to use a programming cable or computer. It just makes it easier.
Volunteer Firefighter
Boone County Fire Protection District
Respect the THIN BLUE LINE!
Old 02-01-2013, 6:39 PM
NE1C4NSC4N's Avatar
The easiest way I have found, without using the automatic download option from Radio Reference(which you need a premium membership for, or be a feed provider which I see you are.), is to use FreeScan, you can copy an entire page from the RR Database webpages, and import them into the program with the EZ-Grab option. It works fairly well in my experience.
You can likely use the EZ-Grab from your other programs, as long as you can highlight and "copy" the list onto your clipboard from the other program.
Old 02-01-2013, 6:42 PM
RonnieUSA's Avatar
It's not easy, but it can be done.
Old 02-03-2013, 1:59 PM
RonnieUSA's Avatar
I found this on Ebay Mini USB to 3.5MM Adapter Jack Plug for MOTOROLA V3V3i will it work with my programing cable I have for my Pro-197?
http://www.ebay.com/itm/190774310994...84.m1497.l2649
Old 02-06-2013, 5:12 PM
I just do it manually. I wonder why the Uniden searches 25.000 straight thru 13.000mhz, and R.S scanners dont? Alot of missed freq seqrches.
Old 02-06-2013, 5:22 PM
RonnieUSA's Avatar
So there is No gap, except for the old analog cell band?
Old 02-06-2013, 5:40 PM
I mean R.S has the gap. They dont go in the 70mhz, 180 mhz range,Uniden does.. Wonder why
Old 02-06-2013, 6:39 PM
RonnieUSA's Avatar
Have no clue, there are some users here where I live that use the 70Mhz band, so I will see.
