  #21 (permalink)
Old 02-04-2013, 9:39 PM
http://forums.radioreference.com/att...llen-stand.jpg
That's a pretty cool looking stand you got. Where can I get one of these and how much it costs? I think it would work perfectly for my shortwave radio as well (about 6" long by 4" high).
BC72XLT
BCD396XT
  #22 (permalink)
Old 02-05-2013, 1:11 PM
bear780ks's Avatar
It's called the Flip stand and it's from Motorola i bought initially for my Razr Maxx but it works really Good for the BCD 396xt but i always looking for yet a better one and i think scanner master has on that is made from metal that holds one or two 396xt's ... b
  #23 (permalink)
Old 02-05-2013, 2:14 PM
bear780ks's Avatar
Is there a way to Add an Alpha tag to a found ID in search on the 396xt for example the city i live in our P.D. uses 2367 as the Dispatch channel and i would like enter it if i can Manually if it can be done..
  #24 (permalink)
Old 02-05-2013, 3:11 PM
=sfdf;1908637]
=It works well, but I'm a bit disappointed that the RadioReference database
seems incomplete for my area on the Starcom & EDACS stuff
StarCom21 Statewide Illinois P25 Trunking System, Statewide, Illinois - Scanner Frequencies
is this system you talking about and what are you missing ?
Originally Posted by sfdf View Post
what I can tell tj\he only system not encrypted are.
1776 6f0 D MWRD Police1 Metropolitan Water Reclamation District of Greater Chicago: Police Law Dispatch
1777 6f1 D MWRD Police2 Metropolitan Water Reclamation District of Greater Chicago: Police Law Tac
If you look at the Data Base anything with an E is encrypted and you are out of luck Listing to it.
I think you are right.... it's not so much that the database is incomplete, it's just that most of the interesting stuff in my area is ENC.
  #25 (permalink)
Old 02-05-2013, 6:30 PM
mule1075's Avatar
Send a message via Yahoo to mule1075
Yes it can be done.When that talkgroup comes up again press enter and save and then edit the tgid to way you want it to say pd dispatch or pd one or dispatch your choices are endless to make it the way you want it.i think i might have missed a few steps but i am not sure on the work pc and not at home.
Uniden 200xlt/250d/8500xlt/780xlt/796d/996t/346xt/396xt/HP-1E
Radio Shack Pro-2006/160/197.AOR 8200MK3
My Scanner Feed http://washpascan.no-ip.biz:8001/
  #26 (permalink)
Old 02-05-2013, 7:21 PM
bear780ks's Avatar
Red face
Adam: Ok when it lands on the TGID i wanted which is pictured i tap E for Enter i get what's in the Picture below.. When i tap Enter again which i assume i need to do i get what's in the Second picture is that OK or do i need to tap something else to store and set the Tag.. Thanks Ra
  #27 (permalink)
Old 02-05-2013, 7:35 PM
bear780ks's Avatar
This should be easy thing to do but it's more of a hair puller than any thing.. Just to tag a An ID tag maybe this will help my frustration
Bobby McFerrin - Don't Worry Be Happy - YouTube
  #28 (permalink)
Old 02-05-2013, 7:37 PM
KevinC's Avatar
Moderator
I believe you've reached the 500 TG per system limit.
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
  #29 (permalink)
Old 02-05-2013, 8:30 PM
bear780ks's Avatar
Meaning i would need to get rid of some ID's kevin that would not pertain or what i would care to listening to! ----
-To add the ones that i do want) i would need to remove or delete the unwanted one's if Possible to do Correct!
When the 396 was programmed all of this stuff below was put together...
It's set up like this: in one hole GRP..
KSICS system part of it
Butler County all of it
Whichita / Sedgwick Co. all of it
Mcpherson Edacs
Kingman
  #30 (permalink)
Old 02-05-2013, 8:49 PM
KevinC's Avatar
Moderator
Mcpherson Edacs
Kingman
Whichever trunked system that TG you are trying to save is on (my guess would be KCICS) has reached it's 500 TG limit, so yes, you would need to delete stuff you don't want...or put them in a completely different "system" in the radio.
BC-210XLT
  #31 (permalink)
Old 02-05-2013, 9:08 PM
bear780ks's Avatar
Kevin i think i found away around this issue on the KSICS there are some TGID's i'm not into listening to i think i can just put in a Clear a TGID write a new in that space and the new Tag and that should work.. i'm hoping wish me luck
  #32 (permalink)
Old 02-05-2013, 9:41 PM
bear780ks's Avatar
Wink
Kevin i kissed the friggen Dalmatian and it worked buddy what i done i took some of the TGID's that i didn't give a hoot about changed the number and the Tag from what it was to what i wanted.! my Sheriff , PD and fire thanks again for your time.. I might be loven this little dude a little bit more the more i tinker and get the good advice..
  #33 (permalink)
Old 02-06-2013, 5:35 AM
KevinC's Avatar
Moderator
Good deal!
BC-210XLT
