Old 02-04-2013, 10:38 PM
Para078's Avatar
Default BC785D Trunking Problems.
I have a 785D that locks up on trunking systems. It works great on conventional systems, but locks up if it's scanning a trunked system. Is this a programming issue or do I need to sent it to Uniden for repair of this and it's other issues?
Old 02-04-2013, 10:45 PM
doctordialtone's Avatar
Default 785D
See if this points you in the right direction:
Uniden 785d digital scanner
~Doctor Dialtone
BCD996XT, BCD396XT, PRO 2004 Modified, BC2500XLT Modified, Minitor V
This post is worth another 4 RR points towards free trips and other valuable discounts!
Old 02-04-2013, 10:55 PM
Para078's Avatar
I don't have the digital card. Just good old analog.
Old 02-04-2013, 11:01 PM
Roger that. Others will chime in here too, so I'll get it started;.
What system are you trying to monitor? Is it Digital? P25? Where are you, within 50 miles? How much change do you have saved up in your cigar box?
Good luck!
~Doctor Dialtone
Old 02-04-2013, 11:08 PM
ridgescan's Avatar
For starters, place the squelch at 12:00 position and see if it starts scanning. Sometimes the squelch threshhold is factory set at a different point than conventional-maybe a QC error. Depending on how distant the intended target is, you might want to go full clockwise to catch noise then back out to just beyond the threshhold. In trunking, squelch matters to catch control channel.
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
