| Uniden Scanners A forum for the discussion of all Uniden scanning radios and receivers. |
02-11-2013, 10:43 PM
BCD996XT - Connecting to PowerPole Connector?
HI,
Has anyone created a cable to connect the BCD996XT to a standard Powerpole connector?
Thanks for your time and help,
R
02-11-2013, 11:22 PM
996XT Power
Originally Posted by kb1dog
HI,
R
kb1dog,
Great radio!
Welcome to RR. The 996XT comes with an AC adapter and will also operate on 12VDC with the appropriate cable. To operate the 996XT on a power pole, simply plug the AC adapter connected to the radio into the Power Pole and rotate the volume control clockwise until you hear a clicking sound. Adjust the level and observe the rich sound.
Is this what you're looking for?
~Doctor Dialtone
BCD996XT, BCD396XT, PRO 2004 Modified, BC2500XLT Modified, Minitor V
This post is worth another 4 RR points towards free trips and other valuable discounts!
02-11-2013, 11:24 PM
I used the included vehicle connection cable and left the orange wire open. Hence, I leave the dimmer setting on manual as the orange lead isn't connected to a headlamp signal line. I use these scanners as base models.
Works perfectly for me. Did this for the BCD996XT and the BCT15X, as well as some older scanner cables.
02-11-2013, 11:59 PM
Thank you, this is perfect and exactly what I was wanting to do.
Best,
R
KB1DOG
02-12-2013, 5:27 AM
Love those connectors.
I run 20+ scanners plus 10 accessories (multicouplers, amplifiers, decoders, etc) in my radio room. All go through 2 Rigrunners (1 w/ remote switch, 1 hot 24/7), all have Powerpole connections.
My programming/repair area is setup for working on various mobile radios/scanners and has a power supply with 2 Powerpole connections. I use small jumpers for various radios (Motorolas, Kenwood, EFJ, Uniden) for power at my workbench.
chris
02-12-2013, 6:05 AM
Go for it!
I have 2 996XTs and 2 BCT15Xs hooked up to one of these: RIGrunner 4012 - Starter Kit [RR-4012-Starter] - $154.03. It is powered by an Alinco power supply. I believe this this THE best way to manage multiple scanner AC power. I will see if I can find my camera and get some pictures!
Manny
N1SQB Amateur Extra
The difference between men and boys, is the price they pay for toys...
BCD996XT, BCT15X,396XT,346XT,GRE-PSR 310,Grundig G3,ICOM IC-7000,Motorola CDM1550LS+VHF/UHF,HT-1250UHF
02-12-2013, 8:56 AM
Thank you all so much... not only does this solve my current issue, it will likely solve issues for years to come. It also perfectly introduced me to this awesome group!
Best,
R
