Ah, ok I understand completely. Your area does not use the 8.33khz spacing, and you desire 25khz steps to speed things up, even though the 8.33khz steps will land on 25khz spacies eventually, but takes time to do so.
Since you want both civil and milair coverage, along with the ability to change "band defaults", then the 396XT will allow you to do this.
