Originally Posted by lost_in_maine
Just had this crop up today...
Running Windows 7 x64.....Did a uninstall, and clean re-install made no difference
Arc Patrol is working fine
Did you do a shut down and cold startup after the uninstall? (not restart)
It sounds like something corrupted the registry entry.
Next thing to try after uninstall is to run Regedit from a command prompt and remove the Sentinel information manually. DO NOT TRY THIS IF YOU ARE A NOVICE!!!! You can seriously screw up the entire computer if you made a boo boo!
Cold start again, then reinstall Sentinel directly from the HP-1 website, just in case your local install file is corrupted.
I just got a new Dell laptop with Windows 8. I HATE IT ! They would not even allow me to pay extra to have XP Pro installed and Windows 8 removed.
JK
