Originally Posted by lost_in_maine
So If you enable Location Control, and scan your favorites, as I have a lot of statewide stuff, and Federal that I listen to, Will they be voided out,if You are out of the set Range?
In a nutshell - YUP.
Now FWIW. I almost exclusively use favorites, unless I am on an out of the area trip it's a favorite.
I have mine as such. All these have no location control.
Local area - what I listen too 100% when at home. This is extremely local only no surrounding counties or services.
Surrounding counties
Special operations, various "stuff" for special circumstances, Rail, EPA, Air, WX, Electric Utilities
And ONE with location control ON. It has a larger section of the state. It's been tweaked to eliminate a lot of extraneous crap. The ranges have also been adjusted on some. I use this when traveling out o the local county, but within this section.
Of course you can always load multiple favorites which I do as conditions warrant.
HP-1, BC780, BCD996, Pro 2005, 2006, AT803,R5000
and other RF capture devices
-Remember Bill Cheek -
