Problem with Firmware Update for BR330T
I hope someone has some ideas that may help me with the following problem.
1. Recently purchased BR330T scanner
2. Firmware version is 1.00.02
3. Downloaded BC_VUP software and BR330T_V1_01_05 software to update firmware
4. The file BR330T_V1_01_05.scn is created when the above file with the same name is
unzipped
5. When I attempt to update the firmware after connecting the BR330Ta Communication
error (117) message.
I also have the ARC330 software which autodetects the BR330T and with which I have downloaded frequencies and operated the scanner in virtual mode.
Is there some subtle thing that needs to be done with the BC_VUP software or scanner that I'm missing? The process seems pretty straightforward (connect scanner, set com port, open file, and start).
Thanks for any assistance.
Julius
