Old 04-22-2006, 08:34 PM
safetyobc's Avatar
Send a message via Yahoo to safetyobc
Default BCD396T New Firmware Audio
The new audio adjustment isn't as good as I thought it would be.
As a matter of fact, the audio on mine at higher volumes is now distorted where it wasn't this way on the version 1.10.
I think I am going back to the old version for the better audio.
matt
@trooperoutlaw on twitter
Scanning Arkansas Yahoo Group
Old 04-22-2006, 09:20 PM
DaveIN's Avatar
What reference gain and time are you using with your AGC?
Old 04-22-2006, 09:24 PM
safetyobc's Avatar
AGC have tried it off and on.
Haven't messed with the "settings" because it says once you power off the option is gone so I was trying to wait for the next "official" release of that feature.
matt
Old 04-22-2006, 09:48 PM
matt
When you turn it off, only the menu and options disappear but the actual settings remain. Once you active the feature, you can just keep adjusting and tweaking until you turn it off or the batteries die. And when that happens, just turn on the feature menus again.
Don't see a reason to wait for the firmware with the permanent menus to experiment.....
JETorres
Old 04-22-2006, 09:51 PM
safetyobc's Avatar
Originally Posted by kikito
When you turn it off, only the menu and options disappear but the actual settings remain. Once you active the feature, you can just keep adjusting and tweaking until you turn it off or the batteries die. And when that happens, just turn it on again.
Exactly. What if I get it set and decide in a few days it needs more tweaking. The option is gone?
Old 04-22-2006, 09:59 PM
No, in a few days you use the trick to bring the settings up when you power on.
Nope, just turn it on again the same way (Hold + Power on).
JETorres
Old 04-22-2006, 10:02 PM
safetyobc's Avatar
OOOOOOOOOOOOO
I understood it to mean once it is gone it is gone.
Thanks guys. I'll tinker with it.
Old 04-22-2006, 10:05 PM
DaveIN's Avatar
I was thinking an adjustment to your Reference (REF) Gain setting would help to make your volume more equal.
Did you see this: http://uniden.com/files/BCD396T%20Fi...on%20Notes.pdf
Old 04-25-2006, 12:06 AM
cristisphoto's Avatar
Default Audio Agc
Wouldn't the audio AGC set too automatic work??
If I am wording it correctly,,
Anyways,
I hope it works out for you so I could apply whatever you did when I get my BCD396T
next week
Regards,
Crista
Hoo Ray Freedom !!!!
Similar Threads
BCD396T and Pro96 side by side. jpm General Scanning Forum 19 02-02-2006 06:39 AM
BCD396T and BR330T Firmware Updates UPMan Uniden Scanners 9 12-11-2005 04:28 PM
BCD396T - audio only through headphone jack... avalys Uniden Scanners 6 09-18-2005 02:58 PM
BCD396T Audio issues (prob a newb issue) bo_duke Virginia Radio Discussion Forum 3 08-30-2005 02:52 PM
AOR 1000 skyyview AOR Scanners 8 05-16-2005 08:13 AM
