If you will be using this "remote" as your primary means of controlling/using the radio, then I suggest implementing as many of the receivers functions as possible. If you are going to go through the trouble you might as well make it as complete as possible.
I've developed a few remotes for the uniden receivers, and its always been a challenge establishing a reduced function set that still allows adequate control over the receiver. The newer protocols are simple enough to use, you might as well go all out.
