Old 06-13-2006, 3:31 PM
Dubbin's Avatar
Default 396 case?
Is there any case out there that fits better then this nylon case that I just got from Grove? This thing is like 2 sizes to big and looks terrible. Also there is nothing holding the radio in unless you have that massive belt clip on it. I would like a nice snug fit soft leather case.
Dwayne
My Scanner Feed
Old 06-13-2006, 3:55 PM
Concrete1's Avatar
Center of the category, custom made for the 396T:
https://www.webtrix.net/shopcart/adv...ners%3C%2Fb%3E
Old 06-13-2006, 3:56 PM
Dubbin's Avatar
Thanks but that is a hard leather case with no protection over the display or keyboard.
Dwayne
My Scanner Feed
Old 06-13-2006, 3:57 PM
safetyobc's Avatar
Forums Moderator
Send a message via Yahoo to safetyobc
I have a lilkase case that fits like a glove. It looks good and is good quality.
Unfortuneately I think they have went out of business.
Maybe Glenn at ScannersUnlimited has some that would look good?
Old 06-13-2006, 4:01 PM
Dubbin's Avatar
Yes I think they are out of business. All Glenn has is the same case as in the link above and the one I have now. I guess I'll just have the wife shorten up the strap on the back of what I have now to make it fit tighter.
Dwayne
My Scanner Feed
Old 06-13-2006, 4:04 PM
Concrete1's Avatar
Also check local Camping/marine/ stores for a possible "pouch" that fits good, but is made for some other product.
Old 06-13-2006, 6:14 PM
kc8syo's Avatar
I have the leather case with the plastic windows top and bottom I bought from Scanner Master $29.95 + $6.95 shipping the code # is 01-581010 I hope that helps.
Old 06-13-2006, 7:33 PM
mike_s104's Avatar
I have the one that Grove sells too (I got it somewhere else). it looks like a hand-me-down and I am embarrassed to be seen with it. it works and I use it but it's ugly as sin.
does Uniden have a leather case out? I thought I saw the part number somewhere.
Old 06-13-2006, 7:38 PM
Dubbin's Avatar
The one grove sells is the same thing as Unidens case. My wife fixed mine up for me about an hour ago and I'm happy with the results. Now it fits MUCH tighter and looks like it was made for the radio.
I don't like the belt part on the one from scannermaster. If it had a clip instead of the belt loop then thats what I would have bought.
Dwayne
My Scanner Feed
Old 06-13-2006, 9:57 PM
RISC777's Avatar
Ditto, Dubbin.
Rich and Sumner carry a great leather case. Everything's covered except the top with openings on the sides for the Func/Menu and power/interface ports. Even a hole at the bottom to drain water if for some reason liquid gets in. Sturdy belt piece which you have to turn the scanner upside down to release it from the holder. They also carry a "visor clip" that this leather case fits to exactly as to its belt clip. Very sturdy, well sewn, takes abuse and doesn't show it.
edit: Dubbin, really, I think you'd like the belt piece of it. Really.
Doesn't expecting the unexpected make the unexpected expected?
Old 06-13-2006, 11:00 PM
Dubbin's Avatar
Other then dress belts I never wear one so no, I dont think I would like it I'm perfectly happy now with the case I got after my wife made a minor adjustment to it. It fits nice and tight and needs to be unsnapped for the radio to come out.
Dwayne
My Scanner Feed
Old 06-13-2006, 11:27 PM
Dubbin's Avatar
Whoops that was the wrong picture. You can see in this one that it fits nice and snug.
Dwayne
My Scanner Feed
Old 06-14-2006, 6:55 AM
safetyobc's Avatar
Forums Moderator
Ditto, Dubbin.
Who is Rich and Sumner? Where is this case?
Old 06-14-2006, 8:33 AM
Dubbin's Avatar
That would be scannermaster.
Dwayne
My Scanner Feed
Old 06-14-2006, 8:35 AM
safetyobc's Avatar
Forums Moderator
O, Okay thanks.
Old 06-14-2006, 10:26 AM
Default 396 Case?
Try the Icom LC-151 R3 Case. It's soft leather, fits very well, and has a plastic cover over the key pad except for a small opening over the scan button. If you take the metal post off the back of the scanner it fit's perfect to carry the scanner around in you pocket. If you make some minor cut outs to the leather in the back of the case you can use the the Uniden belt clip. The case has worked very well for me.
Old 06-14-2006, 10:34 AM
DaveIN's Avatar
Correct me if I'm wrong, but isn't the Watel and Uniden soft case, one and the same?
Mine fits quite nicely, protects all but the top earphone jack, and looks good. Now all it needs is an aftermarket eaphone jack stopper.
Old 06-15-2006, 3:09 AM
RISC777's Avatar
O, Okay thanks.
Here's a link to it.
Old 11-26-2010, 12:56 AM
I am looking at the leather case for the 396. I would be interested but I can't find the 'visor clip' that the case will fit into. Anyone able to point me in the right direction?
Mike KD8LOO
Listen Live: http://tiny.cc/listen-to-apd
