996 Question Re USAD Software Using
Hello:
All this is pretty new to me, so please bear with me.
Basic Question on the Uniden USAD Software:
Scanner View is, of course, an up-load of what's in the scanner presently.
When I go to Scanner Configuration, a single File shows up
that is labeled: Preload BCD996T
Am I correct that this file has nothing to do with what's in the
scanner presently.
Correct ?
But, it only gives you an opportunity to-
a. re-load all the defaults that came with the unit originally, or
b. Modify this file, save it under a new name, and re-load it to scanner.
Is this correct ?
This file seems to have many more user-friendly screens that I cannot
find in the Scanner View upload,or the options presented.
What's the best way to modify what's in the scanner now ?
Is it "best" to just use "Preload BCD996T" file, modify it, save it
under a new name, and then load into scanner ?
Or, use the Uploaded File (the screens for which don't seem to be as straightforward)
Either ? What's best, anmd easiest ?
BTW: saw several mentions to leave Data Skip off.
Seems like this would be a good thing to leave on.
What are the pros and cons for having it on ?
Thanks,
Bob
