Old 07-14-2006, 09:51 PM
jrs71's Avatar
Default 996 question
I currently have 6 systems programmed in my 996 using ARC996 beta. In scan mode, and on one particular conventional system only, the letters 'DSKP' appear each time this system is scanned. This shows up on the top left part of the screen, exactly where 'HOLD' appears in Hold mode. I couldn't find anything regarding this in the owners manual, nor in the ARC996 manual. Anyone know what DSKP is?
Thanks, Randy
Old 07-14-2006, 10:02 PM
wm8s's Avatar
"Data skip." You can turn this on or off.
Old 07-14-2006, 10:15 PM
jrs71's Avatar
Thanks, I found it upon reviewing the software setup....Awesome scanner but a bit of a learning curve here from the scanners I am used to.
Similar Threads
996 question for owners les108 Indiana Radio Discussion Forum 1 07-13-2006 10:44 PM
?s re: Setting Up 996 & Reviewing Locked Out Freqs jimlawrence Uniden Scanners 0 07-09-2006 09:04 AM
996 Question Re USAD Software Using BOBRR Uniden Scanners 0 07-02-2006 10:30 AM
Where are the 996 SQL Steps Expanded? brianfoy Uniden Scanners 1 06-10-2006 10:18 PM
