nyscan asked this question on another thread:
Originally Posted by nyscan
I notice a few complaints about the stock antenna. Is there another multiband, rubber duck type antenna that is better?
As I wrote a response I came to the realization that this was worthy of a new topic so here is my 396 antenna rant.
I am of the opinion that antennas make a big difference with the 396. This is especially true with any digital communications. An antenna tuned to the frequencies you want to monitor is essential. I have a bunch to choose from.
There are a few standouts for me though.
One is the diamond srh77ca. Not a short antenna but quite effective over a broad Ange of freqs, a good general monitoring antenna.
The RS 800mhz unit is not bad at all.
Another is the small Watson W889 telescoping antenna.
The Maldol telescoping antenna is a rather good one as well.
I like telescoping antennas for obvious reasons. not the least of which is because by nature they are tunable
One of my secret antennas is from a company called remote audio. It costs $22.00 for the SMA version. These are tunable (by cutting) high quality UHF antennas. For the money they can't be beat. When people see it they always ask about it because they come with little colored beads so you can match the RX to the TX. I have like 8 different colors on one of mine and it attracts attention. sometimes not a good thing, It is kind of fun though. They are designed for the very rigorous work of Eng television wireless microphone transmitters. I have found them to be fine antennas. Very small discrete (unless you are like me) and they are just plain heavy duty though they don't have the bulk of a big heavy duty antenna. (BnC version available for something like $13.00.)
I have a smiley antenna tuned for the VHF AIR band which borders on ridiculous because as a telescoping antenna it will scope out over 6 foot. It is big and unwieldy. But it pulls in air traffic fantastically.
If you are finding that your 396 is not as sensitive in a band as you would like it to be throw on a tuned antenna it might make the difference for you. Here in LA with the LAPD being an non trunked but an APCO 25 digital agency monitoring them can be a challenge if you are far away from the tower you want to monitor. A good antenna tuned for 5oomhz is a must.
A buddy of mine made me a couple of home brews tuned there and they work wonders. I am often (but not always) able to monitor valley simplex communications from LAX with them. Not bad (thanks Henry). As a scanner freak my best weapons are antennas.
You can never have enough of them. Oh and some are real dogs too.
One time I went into my local radio shop which shall remain nameless, and I noticed some fancy new antennas with SMA connectors on them no less. I immediately picked one up. got to the car put it on the radio hit scan and did hear jack. The antenna looked great but did not work worth a darn. when I went to return it I saw another fancy antenna (BnC) so I returned the crap from a big antenna manufacture and picked up the other fancy AIR band antenna called a maldol AL 500. This is a fine example of a tuned multiband antenna. It is a VHF and UHF air band antenna. you know what? It works very well. Very fancy and expensive. Is it worth the high price probably not. Unfortunately for me, this obsession with antennas goes along with my scanning hobby. Sorry about the antenna rant but I just figured I would cover as much ground as possible on this one.
The long and the short of it is to be as effective as possible your scanner needs good tuned antennas. So go get some.
Before you go here are my TOP THREE must have antennas for LA not in anty particular order:
my buddies 500mhz home brew.
the remote audio UHF with SMA
the Watsom W889
What are yours?
Here are a few of my antennas"
