| Uniden Scanners A forum for the discussion of all Uniden scanning radios and receivers. |
08-14-2006, 09:23 PM
AC Adapter for BCD396T
My original AC adapter that came with the 396 is dead and needs replacement. I was looking at the RS 6v AC adapter ( http://www.radioshack.com/product/in...tId=2049709&cp ) as a possible substitute for the original one. Any ideas, experience or thoughts on this adater?
08-14-2006, 09:30 PM
I'm using a couple of those, to make using my 396 & my BR330T in alternate locations around the house easier. The slimline design also is more 'outlet friendly' than a regular wall-wart.
Get Adapt-a-plug "B".
BCD996T-BCD396XT-BCD396T-PSR500-BR330T-BC246T-BC250D-BC780XLT
08-14-2006, 10:18 PM
Thanks for the reply. I like the slimline design too. It's amazingly small compared to the original one.
08-15-2006, 02:22 AM
BTW the non slimline one will give an illegal voltage error
08-15-2006, 11:56 AM
I went ahead and purchased the slimline adapter. Working great so far. Stormchaser, what voltage is the other one putting out?
08-15-2006, 12:50 PM
I thought that the 396 called for the "H" adapter. At least that's what I used when I bought the DC cord.
Gary
08-15-2006, 01:44 PM
Definitely a "B" adapter from RS for the 396. I'm using one right at this moment.
08-15-2006, 02:15 PM
Thanks.
Gary
08-15-2006, 10:12 PM
They may have given him the 6v, 300ma adapter. Even though it's the correct 6 volts, the 396 (and for that matter, the BR330T) reacts to the low amperage output with an "illegal voltage" error message. Got the same error when I had a brain warp & plugged my 396 into the 246's adapter, which is lower curent. (The 246 runs on two batteries instead of 3.)
No damage, just did not work.
08-21-2006, 05:43 PM
A friend just bought the correct one (6v 800mA) and was getting the "illegal voltage" display. When connected to a meter, it read 11.45 volts! Go figure. I talked him into exchanging it for the slimline version.
08-22-2006, 02:28 PM
It's not producing the correct voltage. It's an unregulated supply, hence the "Illegal Voltage" error. 396T's need a regulated supply. Some, like the 246T, don't.
08-22-2006, 10:16 PM
The 246 adapter that gave me an 'illegal voltage' error on the 396 was the original Uniden adapter, not a R/S or other substitute. However, I did not throw a VOM on it to see whether or not it's a regulated supply.
08-23-2006, 02:09 PM
It's not. The 246T doesn't need a regulated supply, so Uniden isn't going to waste money on one.
10-13-2006, 10:02 PM
'illegal voltage'
If you get the 'illegal voltage' just get any 6v with over 800ma and you should be fine. Radioshack (the Source in Canada) has a 6v 800ma but it didn't work until i got over the 800ma then everything was fine.
