Old 12-26-2006, 11:01 PM
Default Hey Upman, 796d 3.29 download
Hello, I tried to download the 3.29 update from the website but a message says it doesn't know what program to use to open the update, never had this problem before, can you help? will this download help to grab the signal a little better so I don't get that annoying warble noise just before the audio becomes readable? thanks in advance, scannerdweeb.
A Special Thanks To All Soldiers,Police,Fire, and EMS Personnel for all they have done for all of us, and our families!
Old 12-26-2006, 11:19 PM
JoeyC's Avatar
These downloads are zip files. You have to have an unzip program on your computer to open it. This is a common archive format and is not a Uniden problem.
Old 12-27-2006, 10:12 AM
I did unzip the folder and read the install instructions but it said unable to open because windows does not know what program created file, then it tried to search online for the creator and unable to find. sd.
Old 12-28-2006, 11:33 AM
UPMan's Avatar
Uniden Product Manager
1. Unzip the files to a temporary directory.
2. Run "Setup.exe" from that directory.
3. After install, click on the BC_VUP icon on your desktop to run the update.
Got a question? Ask it in a public forum for faster response.
My Home Weather Station
Old 12-29-2006, 08:12 PM
ok, I performed steps above, but when I hit the bearclaw there is nothing there to run, it is empty, also when holding the l/o and 6 buttons when plugging in the a/c power nothing shows on the radio that I am in any other mode for programming, it stays in scan mode.
I have downloaded to this radio before with no problems. ?????? sd
Old 01-01-2007, 12:41 PM
OK, I finally got the firmware loaded, don't ask what I did different, but it loaded succesfully. Now I noticed if I try to enter a freq by entering the digits directly and hitting enter, I get a message saying "enter lock" however the enter lock fuction in the menu is in the "off" position. the frequency can be entered ok going through the menu system. Don't know if during the power up and key holding for setup before downloading I pushed a wrong button, Is there some kind of reset procedure to perform. Scanner seems to be operating ok otherwise. thanks, Scannerdweeb.
Old 01-01-2007, 12:54 PM
JoeyC's Avatar
The screen mask is on. Turn it off.
Old 01-01-2007, 07:52 PM
You are correct. Thank you for the expertise, where did you get the info though? I've never noticed that before. Thank you again, I should be set for awhile, maybe I can answer some questions for you someday. Scannerdweeb
Old 01-02-2007, 12:13 AM
JoeyC's Avatar
I ran into the same problem waaay back when I got my 796 and somebody came to the rescue here.
Old 01-03-2007, 11:19 PM
Angry bc796d
ive downloaded all the software and did everything possiable to upload new firmware and hit all the buttons 500 times now. any suggetions before i get my 9 mm out??
Old 01-03-2007, 11:20 PM
JoeyC's Avatar
Re-read the instructions?
Old 01-03-2007, 11:27 PM
hey joey i re read these a millon times i have no luck
Old 01-03-2007, 11:31 PM
ive even unistalled the software and reinstalled and it automatic installs. also when it looks for the **SCN file there is not one.
Old 01-03-2007, 11:34 PM
also i get rewrittng is impossiable and its not a something for bc
Old 01-03-2007, 11:46 PM
Dubbin's Avatar
Chief if you would give the exact errors then maybe someone can help you.
Dwayne
My Scanner Feed
Old 01-03-2007, 11:53 PM
this scanner is not a object for bc
rewritting is impossiable
please turn off power and remove the cable
Old 01-04-2007, 12:09 AM
i got it now, i have to hit the scan,lo annd 6 at the same time.
Old 01-04-2007, 05:46 PM
Those were the same incorrect instructions I was given several times, then one magical time the file opened and the instructions changed to the scan,l/o,6 command and everything went fine. I too, downloaded updates to this scanner before w/o all the problems this file gave me, corrupted????, Glitch?????? Did you notice any changes in performance on you scanner? Reception??? scannerdweeb.
Old 01-04-2007, 11:25 PM
very little ... but i was about to put a 9 mm into the from of the scanner let me tell ya.
Old 01-05-2007, 12:50 AM
Dubbin's Avatar
Well that sure would have gotten it to work...
Dwayne
My Scanner Feed
Similar Threads
hey upman, 796d card errors? scannerdweeb Uniden Scanners 40 02-15-2010 09:34 AM
Hey UPMAN whats up with this? jpm Uniden Scanners 20 11-25-2006 01:22 PM
