Old 01-12-2007, 12:30 AM
Default Uniden software vs. Arc396
What's the difference between the free Uniden software and the arc396 software?
The price, of course, but what really sets the arc396 apart from the free software?
What does the arc software have or do that the free uniden software can't?
I don't prefer to pay a lot of money for something that does the same job for free, ya know. I've downloaded a free trial arc396 and it didn't appear to do anything different, though it is a trial.
Thanks!!!!!!!!!!!!!!
Old 01-12-2007, 12:40 AM
Dubbin's Avatar
The ARC software will do several things that the Uniden software will not do (depending on the version). Its also MUCH easier to use. Just look through the features on BuTels site and compare that with Unidens.
All Uniden will do is program and control the radio. ARC (PRO) will program, control, RadioReference Import, WebCatcher (trunk), Firmware check, Data logging/history, Recording, Closecall/Subtone logging.
Dwayne
My Scanner Feed
Old 01-12-2007, 09:28 AM
hankv's Avatar
Uniden UASD also does TGID logging - you just have to tell it to Save As... if you want to keep the info.
Retired? I never got over being tired the first time
KI4UMX
Yaesu FT-8800R
Icom IC-92AD D-Star
Uniden BCD396T
Radio Shack PRO95
Yaesu VX-7RB
and other stuff
Old 01-12-2007, 09:41 AM
hankv's Avatar
Uniden UASD does your basic programming, arc396 does additional things that I haven't found a need to do yet.
UASD is good for someone like me who has a limited number of fairly small systems to scan. Someone with large or multiple would probably find arc396 useful.
KI4UMX
Yaesu FT-8800R
Icom IC-92AD D-Star
Uniden BCD396T
Radio Shack PRO95
Yaesu VX-7RB
and other stuff
Old 01-12-2007, 09:45 AM
newbie's Avatar
Matter of opinion on that. I use both for the 396 and 996. Some aspects I find easier to use in the Uniden software.
Download both and try both before you buy.
Old 01-12-2007, 10:04 AM
fireant's Avatar
I have tried both on my 396, 330, and 246 and found the USAD software to be more user friendly.
fireant
Old 01-12-2007, 10:40 AM
MarkWestin's Avatar
Since you are talking about the BCD396T, the UASD software is free for that model. If you are not familiar with either ARC396 or UASD396, then you can try out both. When I was in the decision process, for my BC246T, neither were free (neither are still free now either). I tried out both, and found ARC246 much easier for me to use, so I bought it instead of UASD 246. I had to spend $10.00 more for the ARC246 than I would have spent for the UASD246. Since the UASD396 is free, the equation changes quite a bit, free vs $39.95 (basic) or $69.95 (pro). Since I was used to the way ARC software functions, UASD software was less friendly for me to learn, and I bought the ARC software. That said, unless you have a need for a feature that the ARC software has, you can easily get by with using the UASD software until you decide that you just have to have the ARC software, or you could use the UASD software for the life of your scanner if it fills your needs.
KA1TIV
Old 01-12-2007, 06:08 PM
With ARC396 you can download from RadioReference. With UASD396 you cannot. Am I correct?
Dan
KI4QJM
Old 01-12-2007, 06:38 PM
kg4pbd's Avatar
Correct. That one thing is why I think the Butel software is a bargain. With ARC396 Beta you can also download conventional systems directly.
If you do any traveling it's well worth the cost of the software.
Plus, ARC396's on-screen radio controls are great. With the Pro version you have a choice of multiple reduced windows that open only when rx'ing.
Scott, kg4pbd
Old 01-21-2008, 08:34 AM
When I was using the UNIDEN software, I found that I had trouble with some systems. St. Mary’s County Maryland drove me crazy. I could never get things set up properly. The first time I tried it with the ARC396 software, using the Radio Reference feature, the install worked on the first time. It did all the work for me. No guessing and no mistakes. And, this was with the FREE TRIAL version. I could probably just keep using the trial version but after seeing how great it works, I feel that paying the cost of the PRO version is almost an obligation. If you can’t tell already, I’m hooked on the ARC396.
Similar Threads
Uniden BR-330T Software Supra_RZ Uniden Scanners 12 01-01-2007 05:21 PM
BCD396T can't connect to PC using Uniden software! toshik Uniden Scanners 6 10-17-2006 03:28 PM
New Uniden ES200 Software??? swtpc6800 Scanner Programming Software 7 06-16-2005 12:49 AM
NFM freqs w/ Uniden 796 software doctordave Uniden Scanners 1 12-27-2004 08:57 PM
Uniden UASD Software Question bonus1331 North Carolina Radio Discussion Forum 7 12-12-2004 02:43 PM
