BC898T TV CH 8 Problem
Thought I'd ask you guys about this. I've been a scanner listener for years and purchased the new BC898T this past weekend. I have 5 other scanners in the house (BC895XLT, BC245XLT, BC860XLT, BC210XLT, and a BC100XLT). This problem I am having does not exist on any of these other scanners.
The problem: The BC898T does a great job of trunking the Indianapolis MECA systems and Hamilton co EDACS system. My problem is with conventional frequencies. My local county uses simplex, a base to car frequency of 155.130 and the car to base freq of 154.890. On 154.840 I have a solid signal of the TV channel 8 video that bleeds over to my counties simplex frequencies along with other frequencies in that same area. I can clearly hear the audio from TV Channel 8 around 156.000 wiping those area freqs out too. I am located 15 to 20 miles away from the TV Channel 8 transmitter. I put the scanner in my truck to see if it was just localized and drove at least 5 miles in the opposite direction of the TV Channel 8 tower and the signal didn't change much. It is full scale on the S-meter and only dips a little bit when driving around buildings. None of my other scanners or ham gear have this problem. Is there a problem with my scanner? I do not want to purchase a filter, I'm looking at returning the scanner for another one if you guys think it's just this 1 scanner. It does this while connected to the stock antenna, the mobile antenna, and 2 scanner antenna's I have in the attic. If I disconnect all antenna's I don't receive it but I also can't receive anything else.
In the 2 meter ham band, I can pick out TV Channel 13's audio too...Isn't this suppost to be a tripple conversion scanner? The sensitivity is a tad better then my BC895XLT. If I open up the squelch on the BC895XLT I can't hear any of this stuff. On the BC898T, I can close the squelch all the way and it still bleeds through. Using the ATT just drops it a couple bars on the S-meter and makes it completely deaf listening to anything else.
Like I said, I just bought it Saturday so I could exchange it for another BC898T. Ideas? Suggestions? Is there something I could change? What's it doing???? Do you think I included enough details?? HAHA
Brian, N9WP
