What you need is an AC adapter that puts out 12VDC. The scanner specifies 13.8V because that is about what a car's voltage runs at with the engine running. If you read the AC adapter you currently have, It probably says 12VDC. If you were to measure the volatge it puts out, it is probably closer to 13V. I believe the scanner will run on as little as 10.5 or 11V.
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
