Are you searching or scanning? If you are searching, it will stop on any frequency that has a strong enough signal to break the squelch. If you hear a frequency you dont want to listen to, just press the lockout button and it will continue searching and ignore that frequency. If you are scanning, it will only recieve the frequencies that it is programmed to scan. You can also lockout these frequencies while scanning, but if you don't want to listen to them at all, you can just delete them and/or replace them with frequencies you want to listen to.
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
