Old 07-14-2007, 02:19 AM
edgeman's Avatar
Default Uniden programming software for 396
Has any one else experienced this issue. When I am uploading a file from the scanner to the software, the attenuator setitngs are not being saved. I normally set these as I come across noise on a specific channel.
I don't know if I am doing somthing incorrectly or if this is a software flaw.
Old 07-15-2007, 05:05 PM
pyeman99's Avatar
One thing it may be worth remembering is when you "Write To Scanner" make sure you tick " Erase memory before writing".I have found this is required.It makles a cleaner job.
& can overcome various problems.
Best also to set port to 115k or takes ages to write a large config.
Old 07-17-2007, 01:04 AM
edgeman's Avatar
I'll try that. Thanks
Similar Threads
Uniden Software vs Arc996 evets-md Scanner Programming Software 16 03-26-2009 04:44 PM
An ARC996 software record? W4UVV Uniden Scanners 3 07-31-2006 05:20 AM
BuTel software release first free software for Uniden BR330T! Butelsoftware Scanner Programming Software 0 11-03-2005 08:41 AM
Uniden BC796D Software?? ryan3294 Scanner Programming Software 4 10-09-2005 12:25 AM
Don Starr - Uniden Software ?? pratzert General Scanning Forum 3 02-16-2005 07:30 PM
