Old 08-07-2007, 09:18 PM
Default BCD 996 and BCD 396 ?
Wondering if any one has compared the sensitivity on 800 Mhz. between these two? I would expect the 996 to be better, but don't know that. I have the 396 and just ordered the 996 so guess I will find out soon. Can I transfer freqs from my 396 directly to the 996 and how do I do that. If with a patch cord between the two what would it look like. I am familiar with the 396 plug in. Thanks.
Old 08-07-2007, 11:26 PM
I'm not using the two scanners, simultaneously, on identical antennas, listening to the same systems. But my impression is that the 996 is a bit more sensitive than the 396.
As far as 'transferring frequencies', you can't clone from one scanner to the other via a cable, if that's what you're thinking. However, you can use the Uniden UASD software, which is a free download for both units, to accomplish the same thing.
Just download & install the UASD version for the 996 (be sure & select the option with the software key via email). If you already have the 396's version, just copy the *.usd files for any systems you want to share from the database folder for the 396 program to the one for the 996.
The 396 files will load, & scan, in the 996 after you add them to a configuration in the 996 software. You will, of course, need to tweak them with the site location data if you're going to use a GPS while mobile. You can also edit the *.usd files as needed to tag the audio field for the 996 to 'analog', 'digital', or 'all' (a feature I wish the 396 had).
BCD996T-BCD396XT-BCD396T-PSR500-BR330T-BC246T-BC250D-BC780XLT
Old 08-08-2007, 10:22 AM
hiegtx,
Thanks a lot that is good information. I do have the UASD software for the 396 so I will download the 996 version as well. I live in a fringe area for some 800 systems and I am hoping the 996 will do a little better than the 396. I will go with an outside antenna if I have too. Thanks again for the help.
Similar Threads
BCD 996 Problem / Question oldmillspice Uniden Scanners 7 06-26-2007 09:39 PM
FS: Uniden BCD 396 ThePunisher Old Classifieds Archives 1 02-06-2007 09:41 PM
Straight Trade BCD 396 For BCD 996 scannh2005 Old Classifieds Archives 2 10-11-2006 10:02 AM
