I don't know if you can do it thru the arc software, but it is a display mode that you can change directly on the scanner, that will apply to all of your frequencies ... I think it is func then 0 but I could be wrong ... try that out and see ... press hold to stop scanning, then hit func then hit 0 ....... good luck
