Old 01-22-2005, 04:51 PM
Default BC246T UASD DEMO FILES
For those using the UASD DEMO program, there are now files set up specifically to work with the demo in the files section of the BC246T Yahoo Group (http://groups.yahoo.com/group/BC246T/). Here is the post from that group:
Having trouble getting your DEMO UASD to DL to the scanner?
The problem is likely that your system names are not correct,
or not correctly assigned in your configuration file.
Here are some files that will give you a head start.
http://groups.yahoo.com/group/BC246T...0DEMO%20FILES/
You WILL have to edit the system files to change the data to
frequencies, TGs, control channels, etc. for YOUR area. (unless you live
near Fayette County, PA - the Motorola file is for that system, as I got
tired of making generic files)
This config contains ALL FOUR possible system files/names and each is
assigned to a different System Quick Key (1-Conventional 2-EDACS 3-LTR
4-Motorola). These are the only four names that will work on the demo!
Remember to DL the Config.usc file AND ALL FOUR USD files and store them
in the appropriate directories (the USC file where the other USC files
are, and the USD where the other USD files are)!
Someone WHO DOESN'T ALREADY HAVE local system files, please confirm that
these work on the demo UASD. They should, but have not been tested.
Joe M.[/quote]
