Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Software Discussion
Uniden Software Discussion Topics shall be specific to Uniden produced software though third party non-programming software is permitted. Please see the Software category for all third-party programming software.
  #141 (permalink)
Old 02-25-2014, 11:09 PM
Vonskie's Avatar
New version .12
The font for the date and time is the same size as the rest of the text just bold.
<see newer post for download link>
  #142 (permalink)
Old 02-26-2014, 6:08 AM
mrkelso's Avatar
It's working good. Thank you
  #143 (permalink)
Old 02-26-2014, 7:37 AM
Vonskie's Avatar
You can change your font size now and resize the window after hiding settings.
  #144 (permalink)
Old 02-26-2014, 10:36 AM
Vonskie's Avatar
New version .13
You can now tell it to keep the window on top of all other windows combined with the new resize feature this is nice.
  #145 (permalink)
Old 02-26-2014, 10:55 AM
mrkelso's Avatar
Good Job
  #146 (permalink)
Old 02-26-2014, 1:51 PM
mrkelso's Avatar
If this thing had a logging feature that would really be the cats rear end
  #147 (permalink)
Old 02-26-2014, 2:01 PM
Vonskie's Avatar
Explain what you mean by logging feature?
  #148 (permalink)
Old 02-26-2014, 2:35 PM
Vonskie's Avatar
I never knew there was such software, after a quick look they go from very basic to very complex logging.
I think it would be neat to have a logit it menu item button next to the settings one.
It could show you the last events for the last hour or so you could click on it and it would fill in the date time channel name system name department name freq and then you could populate the notes field.
It would be real simple what fileds would you like to have in the logger?
  #149 (permalink)
Old 02-26-2014, 3:26 PM
Dafe1er's Avatar
Originally Posted by Vonskie View Post
can you do a screen shot on here to show me what an icall is.
Took me a little while today but finally got a snagit of the Icall in progress. If you need more let me know.
Thank you.
I am just a Novice, compared to some here. I am willing to learn and once know what has been taught to me, will help others know this awesome hobby of ours.
  #150 (permalink)
Old 02-26-2014, 4:02 PM
Vonskie's Avatar
New version .15
Found a problem if the department and channel name was not filled out in the database it would not display the transmission info thank you Dafe1er for the screen shot.
Try this version and let me know
I had a few other people complain about transmissions not showing up at times I had no clue what it was until I got the screen shot.
  #151 (permalink)
Old 02-26-2014, 5:47 PM
alphaacres's Avatar
If you could have the UID number and any alpha tag displayed in the next line down on the display that would be cool.
  #152 (permalink)
Old 02-26-2014, 5:56 PM
Vonskie's Avatar
Unfortunately that's all the GLG command returns from the scanner.
When they come out with the reference sheet of supported commands maybe that will change.
  #153 (permalink)
Old 02-26-2014, 6:33 PM
mrkelso's Avatar
Name,Freq,Subtone,Time,and what ever else you can squeeze in there ect and so forth
  #154 (permalink)
Old 02-26-2014, 7:23 PM
Dafe1er's Avatar
New version .15
No, thank you once again.
I have this screen shot of the newer version working the Icall.
It does not alert TTS since the bottom box does not have anything in it. In my favorites list I have it listed as ICalls. Is there a way for this software to read the scanner or just the RRDB?
  #155 (permalink)
Old 02-26-2014, 7:55 PM
How do I get that software
  #156 (permalink)
Old 02-26-2014, 8:11 PM
Vonskie's Avatar
What would you like the TTS to read, I can have it read anything above.
I could make check boxes and you could select what you want it to read.
Too much though and it becomes a nuisance if all the boxes are filled out.
I could say read the first two lines if the last to are not populated. Maybe that would be better.
What are your thoughts give me some ideas?
  #157 (permalink)
Old 02-26-2014, 8:17 PM
I want this software
  #158 (permalink)
Old 02-26-2014, 8:20 PM
Dafe1er's Avatar
Well, just sticking to the ICalls for now I really do not know.
The database does not list Icalls at all. Folk's have to manually enter the Icall setting into the scanners. Maybe since in the Icalls the UID shows an "i" before the UID itself we can have it say> "I", Simulcast or vise versa?
If the software cannot read channels from the scanner or just the bottom line of these new scanners then I really do not know what to offer as an idea.
It really is not that big of a deal as not many people have EDACS systems around them and probably do not know what I am talking about with the Icall....lol
Truthfully, I am waiting to see if you add audio to it so I can stream the audio through the scanner into the PC leaving the scanner on the desk somewhere while doing things in the office. I know at some point this will be around.
I will think for a little while for ideas. Maybe some others can chime in on ideas for this?
Thank you once again.
You are doing a hell of a job for us and this is more than enough for me.
  #159 (permalink)
Old 02-26-2014, 8:31 PM
Dafe1er's Avatar
OK buddy let's give it a shot.
First and foremost make sure you have and installed the serial drivers located at the bottom of the page for the BCD436 from here:
BCD436HP < UnidenMan4 < TWiki
When the serial driver software is installed go to your device manager on the computer and find what com port your scanner is now on. Remember that as you will need it in a future step.
Next go to this link for the newest version of Scanner screen: https://docs.google.com/file/d/0B_Jn...UFU/edit?pli=1
Go to the very first line where it shows:
ScannerScreen / ScannerScreen.exe Executable File 2.8 MB with a drop down box.
Select the drop down box and select download.
Once you have it downloaded and on the PC open the software.
Once you have the Scanner Screen opened plug your scanner in and select the com port setting from above I told you to remember. Once you select the com port select connect to computer. When it is connected you will see "Scanner busy" on the Software screen. Make sure you have the Text To Speech check box marked and you should hear it say the channel that livens up with transmission. Example> Sheriff> Dispatch 1.
Remember that you will need to turn the scanner off then back on before plugging into the USB and using the serial mode. There is a flaw of some sort that does not allow full operation of serial mode on some third party software. This is the work around for it for now.
  #160 (permalink)
Old 02-26-2014, 9:46 PM
Vonskie's Avatar
New version .16
For TTS if channel and department is not filled in it will read Freq + Modulation + Systemname
Dafe1er please test it on edacs icall
