Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Software Discussion
Uniden Software Discussion - Topics shall be specific to Uniden produced software though third party non-programming software is permitted. Please see the Scanner Programming Software category for all third-party programming software.
Old 06-03-2014, 7:35 AM
AC0RV's Avatar
Question Sentinel question
For Verison 1.03.00 , How do I get it. I see only a link to the 1.02 verison
thanks
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
Old 06-03-2014, 8:26 AM
thanks
If you are asking about Sentinel for Home Patrol, the latest version is 2.04 (revision 04).
If you are asking about BCDx36HP Sentinel, the latest version is 1.02 (revision 01).
Are you confusing firmware versions with Sentinel versions maybe?
Old 06-03-2014, 10:44 AM
AC0RV's Avatar
Question
i think iam,then my question is there a newer veision for the software ?
David F AC0RV
Skywarn # M187201
Old 06-03-2014, 11:13 AM
UPMan's Avatar
Uniden Representative
Which software?
The PC software or the scanner software (firmware)?
For whichever you mean, what version do you have?
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 06-03-2014, 11:18 AM
Again, as noted above, those are the latest versions of the SOFTWARE.
Again, not sure which scanner you are referring to.
As far as the FIRMWARE versions,
Home Patrol currently is 2.05.03
436HP is currently is 1.03.00
536HP is currently is 1.03.03
Old 06-03-2014, 5:15 PM
AC0RV's Avatar
sorry I talking about the 436hp.
David F AC0RV
Skywarn # M187201
Old 06-03-2014, 6:33 PM
UPMan's Avatar
New firmware versions are loaded using the Update Firmware option in Sentinel.
Personal Blog
Old 06-03-2014, 6:50 PM
AC0RV's Avatar
UPMAN
I am still having the same problem with updating loading the database as stated in previous posts. It loads to the half way point and it quits. Stating that an error was cause and the underlying connection was cloaed.
I have deleted the program and re downloaded and installed the program and still gives me the same error.
Note : This occurs when I try download the lasted database updated.
I am using ATT's DSL.
I am having no trouble with getting to view sites on the internet with them.
David F AC0RV
Skywarn # M187201
Old 06-03-2014, 7:01 PM
UPMan's Avatar
It sounds like some kind of time-out issue on your system. What DSL modem do you have? (I also have ATT DSL at my home, and routinely update with no problems.)
The transfer uses ftp, which some modems and/or ISPs limit or block.
Personal Blog
Old 06-04-2014, 6:53 AM
AC0RV's Avatar
Smile
The DSL Mode I have is a Motorola.
David F AC0RV
Skywarn # M187201
Old 06-04-2014, 12:44 PM
Every now and then, I'll have a problem with my ATT modem getting sluggish. I'll unplug it for a few minutes and plug it back in. After the re-boot process, my speeds seem to pick-up.
It just so happened I noticed this sluggishness while attempting to do a DB download. Once I did the above, the download went much better.
Old 06-05-2014, 11:07 AM
AC0RV's Avatar
Ok, I disconnected the modem from my wireless router (dlink) and hooked it up to the laptop.
Then I retried the update again it worked. So I am now think its in the router.
Will be looking into it.
Thanks for the help
David F AC0RV
Skywarn # M187201
Old 06-15-2014, 2:56 PM
I was try to see if anyone knows any other way to get the sentinel software. It seem when I go to webpage it is down. The requested document was not found on this server. Is what it says.
Jacob
monitoring everything everyday!
Equipment-MT 2000, BCD996T, BCD436HP, BCD536HP
Old 06-15-2014, 3:33 PM
MikeOxlong's Avatar
If you search, you'll see the reason you can't reach the website and you'll also find another download link for the software.
Mike.
Old 06-15-2014, 3:37 PM
DocDaddy's Avatar
Websites Down for Maintenance
The following websites will be down for maintenance through Monday 6/16/14.
Uniden Scanner Wiki Site at: Uniden Customer Support > Home
My Uniden Registration Website at: Uniden Customer Support > Home
And Repair Website at: Uniden Customer Support > Home
Please check back Tuesday Morning 6/17/14
DocDaddy
HOME PATROL 1 - BCD996XT - BCD436HP - BCD536HP - BCT8 - BC370CRS
"I once found a Carona... It was a Carona-Carona, but I only found half of it."
