Does anyone know if a fix for HP Firmware 2.05.03 is in the works? I reverted back to 2.03 after hearing ambulance traffic on a highway patrol talk group while using 2.05.03
Thanks!
Thanks!
Thanks!
If you read more on this thread, this is a known issue. On Ohio MARCS, and some others, there is a 3 + second hang time, if there is another transmission on the system it actually displays the incorrect TG info.Any chance this could have been a "normal" situation? The ambulance folks could have been told to switch to a highway patrol talkgroup for communications relating to an incident.
Alternatively a patch could have been established linking the ambulance and highway patrol talkgroups. Some times patches between talkgroups are not terminated at the conclusion of the incident/need due to dispatch center oversight.
I hope not! Since downloading 2.05xx my HP-1 is preforming outstanding scanning APCO25. A major improvement!
I'd say you are one of the very few experiencing better results
Actually.. (a) people are much more apt to complain then to praise (meaning that you only ever hear from complainers, and most of the happy folk stay shut up); (2) the overwhelming majority of people with problems appear to be monitoring one or two (or at most a handful of) specific trunk systems in particular.
I'd wager real money that the majority of people are not having problems, and that it is a vocal few with genuine issues with either specific systems or a specific brand/configuration of system.
As Upman has stated, it will be corrected on with another firmware.
I did read the other associated posts. My thoughts were that a very specific set of conditions were mentioned - ambulances on highway patrol - there could be another explanation beside the firmware issue.
Which version sounds best for Motorola P25 system?
