Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Software Discussion
Uniden Software Discussion - Topics shall be specific to Uniden produced software though third party non-programming software is permitted. Please see the Scanner Programming Software category for all third-party programming software.
Old 07-01-2014, 12:21 PM
Default Homepatrol 2.05.03
Does anyone know if a fix for HP Firmware 2.05.03 is in the works? I reverted back to 2.03 after hearing ambulance traffic on a highway patrol talk group while using 2.05.03
Thanks!
Matt
Old 07-02-2014, 1:47 AM
n3617400's Avatar
indirect proof
Old 07-02-2014, 4:19 AM
DSC45's Avatar
I hope not! Since downloading 2.05xx my HP-1 is preforming outstanding scanning APCO25. A major improvement!
Dave . . . ' Scanning Over New Jersey '
Old 07-02-2014, 10:38 AM
Thanks!
Any chance this could have been a "normal" situation? The ambulance folks could have been told to switch to a highway patrol talkgroup for communications relating to an incident.
Alternatively a patch could have been established linking the ambulance and highway patrol talkgroups. Some times patches between talkgroups are not terminated at the conclusion of the incident/need due to dispatch center oversight.
Old 07-02-2014, 11:47 AM
If you read more on this thread, this is a known issue. On Ohio MARCS, and some others, there is a 3 + second hang time, if there is another transmission on the system it actually displays the incorrect TG info.
As Upman has stated, it will be corrected on with another firmware.
BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000and other RF capture devices
Old 07-02-2014, 11:51 AM
03msc's Avatar
Based on many other posts in this thread I'd say you are one of the very few experiencing better results after the firmware update but that's good and if they do release a 'fix' there is no reason you have to upgrade to it if you're happy with what you have now.
Mark Arkansas K D 5 B V X
Uniden Whistler Kenwood Yaesu
Old 07-02-2014, 11:59 AM
Originally Posted by n3617400 View Post
Thank you! I obviously missed the update.
Matt
Old 07-02-2014, 12:49 PM
Jay911's Avatar
Actually.. (a) people are much more apt to complain then to praise (meaning that you only ever hear from complainers, and most of the happy folk stay shut up); (2) the overwhelming majority of people with problems appear to be monitoring one or two (or at most a handful of) specific trunk systems in particular.
I'd wager real money that the majority of people are not having problems, and that it is a vocal few with genuine issues with either specific systems or a specific brand/configuration of system.
--j.
@Jay91150 and @RMESFire | http://www.rmesfire.org
Old 07-02-2014, 12:55 PM
True - but Ohio's MARCS is unusable with this version. Unless you like having a 5 second delay on every TG
As to audio wise or decode, I saw little difference between the 2. I only have the 2 trunk systems in my area.
Old 07-02-2014, 5:12 PM
03msc's Avatar
OK then well I stand corrected.
Old 07-02-2014, 10:24 PM
I did read the other associated posts. My thoughts were that a very specific set of conditions were mentioned - ambulances on highway patrol - there could be another explanation beside the firmware issue.
Old 07-02-2014, 11:41 PM
But not in this case. It's a known issue.
Matt
Old 12-09-2014, 10:49 AM
BobW55's Avatar
I have noticed a good improvement on decoding P25. I get much less garbled speech.
It does seem to have a strange lag after a P25 transmission that I have not been able to see what may be the actual culprit.
Have noticed that the garbled speech is worse when I have a weak signal (PLEASE CHANGE THE COLOR OF THE SIGNAL STRENGTH BARS TO SOME OTHER COLOR THAN WHITE)
I use my HP-1 Mobile most of the time so it is hard to see what exactly is going on. I never hear the garbled stuff when hooked to my outdoor antenna.
This firmware DID make an improvement
Old 12-10-2014, 2:24 PM
jlally's Avatar
Default Difference between firmware versions
What is the difference between firmware additions 2.05.03 and 2.06 for HP-1? Which version sounds best for Motorola P25 system?
Thanks,
John
Old 12-10-2014, 2:30 PM
That would vary from system to system.
