This is one of the most interesting and essential discussions regarding firmware that I've seen on the forum. So which is it? Stored internally on the scanner or written to the SD Card. Can we get clarification from the UPMan?
Thanks.
The
working firmware is in the scanner, not on the SD card.
During the process of upgrading the firmware, the firmware file is downloaded to the SD card briefly through Sentinel, and as soon as the scanner re-boots the new firmware is loaded into the scanner from the SD card and the firmware file is then automatically deleted from the SD card.
NOTE..... If you have prepared a spare SD card from a card reader connected to the computer, including clearing user data AND updating the firmware (so that the firmware file is on the card), when you put that card in the scanner it will read and load that firmware file to the scanner since it is on the card.... even if it's an older firmware.
You can prepare a duplicate card from Sentinel in a card reader by clearing user data and then writing the database updates and your favorites lists to the card, but just skip the "update firmware" step so you won't have a firmware file on the spare card.... that way if the spare has been around a while and you have since updated the firmware on the scanner to something newer than was on the spare card when you made it, putting the spare card in the scanner won't revert to the older firmware.
Easiest to just copy a working card to another one to make a current spare. Neither the working card nor the spare will have a firmware file on it in that case.
