BOBRR
Hello,
Using Sentinel and a BCD436.
A bit confused over the QK Tab that shows all the boxes that
comes up when I go to Edit PROFILES.
Have a bunch of FAV.
They all show up in the left hand pane.
Each one has a QK assigned to it.
Just to the FAV. Not to any Systems, Dept’s, Sites, etc.
If I go to “Favorite Lists,”, and “Edit FAVORITE LISTS” icon, I get the chart
that shows all the QK’s assigned to these FAV items.
Fine.
But if I go to “Favorite Lists, and click on the “Edit PROFILES” icon,
it shows under the QK Tab a chart labeled
“Favorites List Quick Key Status” and all the boxes that can be checked.
It shows that I have, only, the first box (00) checked.
Let’s say I have created 10 FAV. (each with a QK)
Do I want to click on all of the first 10 boxes here before downloading to the radio ?
And then in the Scanner select which of these I want to scan ?
I guess I am not certain what this QK chart (with all the boxes) that comes up when I click on FAV and Edit PROFILE
*And, what menu does this chart correspond to in the Scanner ?
Is it where you have to Enable all the QK’s you want to be able to
subsequently select to scan ?
Thanks,
Bob
Fine.
Thanks,
Bob
