Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Software Discussion
Uniden Software Discussion - Topics shall be specific to Uniden produced software though third party non-programming software is permitted. Please see the Scanner Programming Software category for all third-party programming software.
Old 07-16-2017, 11:29 PM
AC2OY's Avatar
Default Edi ting programming
I have a question reguarding editing programmed stuff in my 536. I want to do some alert lights,delays....ect. So I go into editing favorite lists and make the changes. I then click on save in that window. Then I write it to the scanner but it dosen't save the changes. What step am I forgetting or missing?
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Uniden 536 HP Kenwood TS-2000 Comet 250-B Diamond D3000N
Old 07-16-2017, 11:43 PM
jonwienke's Avatar
You probably have the main database active. You can't edit stuff in the main database, other than setting or clearing avoids. To see your settings in action, turn off the main database, and make sure your favorite list is downloaded to the scanner and active.
Old 07-16-2017, 11:51 PM
AC2OY's Avatar
ok i'm confused here if I don't have my favorite lists active how would it only scan my lists and not the entire zip code. Actually the one thing that I did do correctly was turn off a few lists that I no longer wanted to monitor. It's been a minute since I played with sentintel so I'm a tad rusty. Thanks Jon for responding man!!
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 07-17-2017, 12:16 AM
jonwienke's Avatar
In the scanner menu under Set Scan Selection / Select Lists To Monitor you can toggle scanning of the main database and each of your favorite lists on and off. It sounds like you have the main database (which cannot be edited) turned on, and your favorite list(s) turned off. That will cause the scanner to appear to ignore all the edits to your favorite lists (alert light, alert tones, etc). Make sure the main database is turned off, and your favorite list(s) are turned on.
Old 07-17-2017, 1:23 AM
AC2OY's Avatar
Jon when I go in and edit,do I rewrite the lists option or do I just skip that part/ That might be my mistake I have been rewriting thinking that by doing that it will change what I want it to change.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 07-17-2017, 1:31 AM
AC2OY's Avatar
another question....when you write to the scanner what option am I supposed to use/ One says erase favorite lists or write full database. I don't want to wipe out my lists so i have been using the write full database one.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 07-17-2017, 7:02 AM
jonwienke's Avatar
Check both. You want to replace what is on the scanner with your latest edits and updates. Not checking erase favorites means that Sentinel makes a copy and you have old and new versions of your favorite lists every time you write to scanner.
Old 07-17-2017, 3:39 PM
...and that's why you don't see the changes. The scanner is scanning your original/old and unchanged Favorites List(s) and may not get to the new/revised Favorites List(s).
Also if you don't erase and re-write your Favorites Lists, if you later do a "Read from Scanner" it may really give you a headache by overwiting the changes you made in Sentinel.
Old 07-17-2017, 10:23 PM
AC2OY's Avatar
Thank you both!!! I did a little experementing and tried checking both and the edits took!! Little by little I'm getting it they way I want it.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
