Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Software Discussion
Uniden Software Discussion - Topics shall be specific to Uniden produced software though third party non-programming software is permitted. Please see the Scanner Programming Software category for all third-party programming software.
Old 03-13-2018, 3:07 PM
iceman382's Avatar
Thumbs up BCT15 Software for BCD996P2
Just tried my Uniden BCD996P2 with the Uniden BCT15_UASD_v1.0.8.0 software and it works!
Running under Windows 10 with all current Windows updates.
Main purpose was to test the "Online Control" and glad to say it works and also able to view "extended online control"
logging with TGID's.
Not sure if this was know already, but good to know for others and myself.
Old 03-13-2018, 3:20 PM
marksmith's Avatar
The basic guts from 15 to 996 p2 are the same.
If you use Freescan you can load the same programming to them so all your quick keys remain same, etc.
Only difference is the 15 can't handle digital, but the 996T, 996xt and 996 p2 are identical in Freescan. And same files can be loaded to the 15x, sans digital systems.
396xt, 325 p2 also.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
Old 03-13-2018, 3:33 PM
hiegtx's Avatar
Mentor
Remember that the UASD software was never updated to allow for the custom tables required for some rebanded (non-P25) systems, and that the BCT15 software would not allow for programming digital. FreeSCAN works on both scanners as Mark noted, and can be used to set up digital systems as well as rebanded ones.
Steve
SDS100-436HP (2)-536HP-TRX-1-325P2-among others
Old 03-13-2018, 3:37 PM
iceman382's Avatar
Correct. I use Freescan to program...along with RadioReference.com to import frequencies.
But its nice to know that the old BCT15 software is able to have a relatively nice scanning display on your computer that looks like the 996P2/BCT15 radio.
That was my main reason in trying the software. The computer display of the radio is pretty good.
Also, this post might help others.
Old 03-13-2018, 3:55 PM
iMONITOR's Avatar
Actually they're not. They're completely different. The 996P2 has a lot of hardware differences from the BCT15/15X.
Old 03-13-2018, 3:57 PM
marksmith's Avatar
I am aware of that, but in terms of software use, they are identical.
Old 03-13-2018, 5:25 PM
iMONITOR's Avatar
The exception being Butel's software. He has ARC-15 for the BCT15, and ARC-XT for the BCT15X, and the 996 series.
Old 03-13-2018, 5:51 PM
396xt, 325 p2 also.
Freescan won't load all settings for 996p2 or 325p2, such as number tags or channel volume offset or alert light patterns.
Old 03-13-2018, 6:11 PM
hiegtx's Avatar
Mentor
Actually, FreeSCAN can do these programming functions. Just be sure to uncheck the box for 'Simple View' in order to see the rest of the programming options.
Steve
Old 03-13-2018, 6:55 PM
marksmith's Avatar
Because the author chose to create a special software version for each radio, does not make the radios different from a software perspective.
The fact that Freescan deals with them identically verifies that.
Files for the 996 p2 will load in a 996xt. The radio hardware can't handle receiving phase 2, but it will load the files.
Files for the 996 p2 will load in the 15x. The radio can't handle digital or p2, but the radio handles software in the same way.
Using Freescan, I load the same exact files into a 15x, 996T, 996xt, 996p2, 396xt, and 325p2.
The quick keys are identical through all of the radios that way for my benefit. I deactivate the digital or p2 systems keys on those radios that don't support those systems, but other than that I use the exact same set of data to load each of these radios, and it works just fine.
Old 03-13-2018, 7:11 PM
Thanks Steve, I didn't know that.
Old 03-14-2018, 11:45 AM
iceman382's Avatar
Default Screenshot of BCD996P2 Running on BCT15 Software
Screenshot of BCD996P2 running on BCT15 software.
Old 03-15-2018, 10:48 PM
scosgt's Avatar
If you use the old 996 software BC996T-USAD it will also flash the display on your monitor if you have the backlight set that way.
Also works with the 352.
Old 03-16-2018, 6:17 PM
iceman382's Avatar
Default BC996T-USAD Software
I'll give it a try once I find the download on the internet. I did a quick search and could not find it.
Uniden site is a dead link.....no surprise there!
Anyone have it or know where to find it?
Thanks.
Old 03-16-2018, 6:19 PM
UPMan's Avatar
Uniden Representative
Uniden | A World Without Wires
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 03-17-2018, 7:14 PM
N9JIG's Avatar
Sheriff
That link doesn't work Paul, it gives an error:
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
Rich Carlson, N9JIG
Facts are facts but my opinions are my own and may not reflect those of whom I work for.
Old 03-17-2018, 7:18 PM
hiegtx's Avatar
Mentor
Link did not work for me either, but I found that I have the file saved in an archive folder.
Steve
Old 03-17-2018, 7:19 PM
Originally Posted by UPMan View Post
That link works OK for me.
Old 03-17-2018, 7:21 PM
hiegtx's Avatar
Mentor
Could you get it to download?
The link gets me to the page, but when I click to download it, I get the same error Rich posted. You can click the Download on the landing page. That then takes you to the actual download page, where you have to agree to the terms by checking a box. Then, hit download on the second page, and the error Tesource not found comes up. I get the same errors using Firefox, Chrome, & IE.
Steve
Old 03-17-2018, 7:25 PM
OK, yes... the link given takes you to the Uniden site, but the download link on that page gives an error.
