mpwilson
I've looked through old threads for this but couldn't find the answer for which I'm looking.
I have programmed the SAME FIPS codes into the scanner that I wanted it to monitor. Am I correct that I DO NOT have to turn on the Weather Alert, if the SAME FIPS codes are programmed, and the 436hp will monitor them on the fly.
The reason I ask is that we had a line of severe storms come through my area this evening and I had the WX ALERT turned on and it alarmed for an area for which I had NOT programmed the FIPS codes.
So I guessed that with WX ALERT ON, it will sound the alarm for any alarm the Weather Service sends out that I can hear, but if I leave WX ALERT OFF, it will sound on my programmed SAME FIPS codes only.
It's hard to check this unless you have a storm coming, is the reason I'm asking.
Thanks....and yes I have the Easier to Read Manual, but I don't want to assume anything.
Patrick
Patrick
