Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Software Discussion
Uniden Software Discussion - Topics shall be specific to Uniden produced software though third party non-programming software is permitted. Please see the Scanner Programming Software category for all third-party programming software.
Old 06-08-2018, 4:40 PM
hosehead88's Avatar
Default Missing system
Can someone please check to see if Sentinel shows PA/Dauphin/County and see if the Dauphin County Prison DMR shows on the list. For some reason it does not appear for me to select to add to my faves
FTM-PTB-EGH
West Shore Bureau of Fire
SDS-100/ TRX-2(x2), WS-1088/, BCD996XT, PSR-600(x2), PSR-500/,Pro-2096, Pro-2055, Pro-97, Pro-2026, Pro-2036
Old 06-08-2018, 4:49 PM
kma371's Avatar
Global DB Admin
It does not.
It's likely because it has no known talkgroups. That's normal.
Old 06-08-2018, 4:50 PM
hosehead88's Avatar
Originally Posted by kma371 View Post
It does not. It may be because it's not listed under any subcatagory?
I've added it to a subcatagory at the top, when the database gets refreshed monday, check back and see if it's there.
You are the man!
FTM-PTB-EGH
Old 06-08-2018, 5:48 PM
wm8s's Avatar
In a different, lengthy thread, Uniden has said that they won't "fix" this --- i.e., by making the default be to Search for IDs instead of Scanning for only existing ones --- because they think most users want to ignore unidentified TGs. Specifically, they've said that a system with no IDed TGs is not a "scannable" system. While I think that's ridiculous, a [if irritating] solution is to program the system manually once, monitor it long enough to grab 1 TG, and submit that TG to RR. Voila, it will be in Sentinel the following week.
Old 06-08-2018, 5:49 PM
hosehead88's Avatar
It does not.
Did you add it as corrections?
FTM-PTB-EGH
Old 06-08-2018, 6:04 PM
UPMan's Avatar
Uniden Representative
That mischaracterizes what I said. The main dB has no provision for ID Search. We only put things in the main dB that are scannable. Otherwise, the scanner would waste a bunch of time scanning systems that have nothing to actually scan and generate an entirely other set of complaints. I'm going to stick with the complaints I have.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 06-08-2018, 7:35 PM
W4EMS's Avatar
Good call.
Old 06-09-2018, 12:08 AM
wm8s's Avatar
I don't think I did, but Uniden and I [and lots of others] will just have to agree to disagree about whether it's best for users to give or deny them a setting in Sentinel as to how to treat systems in RR with as yet no IDed TGs: (A) Pretend like they don't exist [the current behavior], or (B) Import them into Sentinel with the system's search type set to "Search" and thus still getting to hear all of the traffic but having to put up with "TG: 12345" [for lots of us, the desired behavior to save us from having to manually enter the system, then miss updates once somebody does ID a TG].
If the problem is in the fact that only systems in the Main DB show in Sentinel's system picker but we don't want "non-scannable" systems in the Main DB lest a non-power user scanning the Main DB has the problem you described, then Sentinel could show all systems in the picker for manual inclusion in an FL, including "non-scannable" ones as Uniden defines that term, but only send "scannable" ones to the radio's Main DB. It seems like such a setting could let everybody get what they want.
Putting this in perspective, yes, it's a pretty minor nit. If I was going to spent time changing Sentinel, I'd much rather have it keep Systems/Sites/Depts/Channels in its copy of the FLs linked to their original RR source data in a way that could detect deletions, let us change long names without getting confused and re-adding them back the next Append to FL, etc.
[Thanks for reading these forums; I suspect that that kind of attention to customer feedback is a huge reason why many of us are customers.]
...R
Old 06-12-2018, 10:00 AM
hosehead88's Avatar
Dauphin County Prison did not appear in the DB update I did in Sentinel. It did appear in ARC536
FTM-PTB-EGH
Old 06-12-2018, 10:08 AM
See post #2 - same answer.
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
Old 06-12-2018, 10:44 AM
hosehead88's Avatar
So I would have to use ARC as well so I could add a system with no TG listed just so I can try to identify if TG do exist...that is a PITA.
FTM-PTB-EGH
Old 06-12-2018, 11:37 AM
Not really - you can manually use Sentinel to enter a system, you can use Discovery, or use ARC since you already have it.
Old 06-13-2018, 12:04 PM
theaton's Avatar
Member N7VU
Trunked systems with a single identified TG also don't show up in Sentinel - at least I've noticed cases where they don't.
Scanning Mountaintop to Mountaintop...
Old 06-13-2018, 2:35 PM
hosehead88's Avatar
So I was able to get the system on the sds via ARC. There are no TGs on the system yet (only one site). Even if I turn on ID search for the system, I can not use the QK to activate scanning. For example, all of my other QK work great (FQK. SQK) activates/deactivates everything else just fine. The system with no TGs just gives me error beeps when I try to use the QK (in this case 0.12E
Another issue caused by same as above?
TIA
Sent from my SM-G965U1 using Tapatalk
FTM-PTB-EGH
Old 06-13-2018, 2:41 PM
TIA
Not sure - but just enter a dummy talkgroup.
Old 06-24-2018, 10:16 PM
hosehead88's Avatar
Still no good. Still get an error when I try to activate the system. It appears in the FL and I can make edits to it on the device, but still the same error. I would just like to be able to try to listen to find the TG on the system. Seems like I can only do that on a Whistler.
FTM-PTB-EGH
Old 06-24-2018, 10:22 PM
UPMan's Avatar
What error?
Personal Blog
Old 06-24-2018, 10:24 PM
hosehead88's Avatar
What error?
When I enter 0.12 and press E, I get three beeps. It will not activate that system.
FTM-PTB-EGH
Old 06-24-2018, 10:28 PM
hosehead88's Avatar
I tried adding 1, then the second channel, to no avail.
BTW - this is for the SDS-100 since when I opened the topic it wasn't listed yet as a device.
FTM-PTB-EGH
Old 06-25-2018, 12:13 AM
pinballwiz86's Avatar
I think ID SEARCH would be better to have when you input the zipcode than ID SCAN. This allows you to find out all active talkgroups before creating a new favorite's list in Sentinel..
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
