Sentinel is my main workhorse for software. I'll use ARC 536 Pro for "pretty-ing up" alpha tags (I like upper case because they are easier on my old eyes).
I created a Favorites List with Sentinel, then read that FL with ARC. Tags were changed to upper case and written to the scanner. I verified the changes on the scanner itself.
When I read the "fancied up" FL with Sentinel, I got the File Changed message Copy and Replace on PC, which I said yes to. After doing the read, Sentinel insisted on displaying proper case rather than all caps as they actually were on the scanner. I did some messing around via the keypad and set an alert light to be different, just to force another change in the file. Sentinel still would not display those changes
However when I did some behind the scenes snooping and opened the actual HPD file using a text editor. All of the changes were there. For example a channel name in the HPD file might say "POLICE 1" but in the Sentinel display/mask/screen, it says "Police 1".
I believe there might be a glitch in the latest Sentinel. Prior to the latest revisions, I was able to edit x36 Favorites Lists with ARC and then read them into Sentinel with the changes being displayed correctly.
