Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
  #61 (permalink)
Old 07-02-2017, 6:57 PM
I am using the Diamond SRH77ca on my 436, and likemit alot. I also have the uniden OEM rubber ducky antenna.The rubber ducky does pretty good,,but the Diamond brings in some more distant departments.
  #62 (permalink)
Old 07-02-2017, 9:58 PM
Watson WSMA-801 for me. Works the whole spectrum of the 436. Looks great too.
  #63 (permalink)
Old 08-31-2017, 7:12 PM
Has anyone tried this one? ULTIMATE* UNIDEN BCD396T BCD396XT BCD436HP SCANNER ANTENNA 700 & 800Mhz DIGITAL | eBay
  #64 (permalink)
Old 08-31-2017, 7:24 PM
jonwienke's Avatar
Diamond RH77CA is my favorite.
  #65 (permalink)
Old 08-31-2017, 11:10 PM
TailGator911's Avatar
I have a BC396Xt and the TRX-1 and when I use them at my desk I have feeds for them from the wideband discone and a directional yagi, but when I am mobile I use a windowsill BNC antenna clip with a Watson W-889 which works wonders. I have heard others complain that the TRX-1 is horrible when mobile but I would heartily disagree. With the aforementioned mobile antenna simple setup I hear it all and am more than satisfied with the Watson W-889.
Scanners: BCD536HP, BC895XLT, PRO-2006, PRO-2051,WHISTLER TRX-1, WS-1065, Misc.
Shortwaves: ICOM R75, ICOM 746 PRO, SDR#
Amateur: ICOM 746 PRO (2m), YAESU 2800M, YAESU VX-7R, ICOM IC-T21A
  #66 (permalink)
Old 09-12-2017, 11:30 PM
Default cable for Tram 1410
I have a Tram 1410 antenna with a female SO-239 connector that I want to connect to my bcd436. What cable/adapters should I use?
  #67 (permalink)
Old 09-12-2017, 11:32 PM
You didn't say what band, that would help. If it's 800 mHz trunked, then the RadioShack 800 mHz rubber duck. Even through RadioShack is (mostly) out of business, they are still plentiful on eBay. The same antenna is also manufactured under the Remtronix brand.
  #68 (permalink)
Old 09-12-2017, 11:43 PM
Isn't the Tram 1410 a multi band antenna?
  #69 (permalink)
Old Yesterday, 10:16 AM
We have a nasty simulcast problem here in Nashville, so when I got my first radio, I joined the antenna of the month club. I've got a bunch of them. The one that works best on the Metro system is the RS800. If I want to hear outside the county, I use the telescope that came with my 536. There's a lot of good interesting here this morning.
Just Old Dan
  #70 (permalink)
Old Yesterday, 10:21 AM
Apologies for my typing. I'm 73 now and I'm beginning to think I need a new processor.
Just Old Dan
