can anyone tell where if they are using and ac/adapter to charge there 436hp scanner I am still charging mine with the usb cord thru my computer would love to buy a ac adapter I do not need another usb cord
I use an ac usb adapter (came with any of various phones) all the time.
Is a standard 5V/1A USB charger sufficient to run the scanner and/or charge the batteries?I use an ac usb adapter (came with any of various phones) all the time.
Ok. Has anyone used a standard Apple iPhone charger (small white cube)?Yes - as long as it identifies itself as a high current charger to the scanner.
Thanks for the advice. I'm guessing because it only charges for a fixed time and doesn't monitor the actual charge level, so you can overcharge and cause heat and possible fire?DO NOT....Use your radio as a battery charger...
Nope. I'm pretty sure I saw a post from UPMan saying that the 5V 1 Amp USB didn't supply enough power to do both.
