I have put together a list of some keypress codes for the Uniden UBC126AT. All of these work by holding the keys listed as the UBC126AT is turned on. I don't know if the same key codes work with the BC125AT.
2 + 9 + Hold = Factory Reset
1 = Country Mode Australia
2= Country Mode New Zealand
Hold + 3 = Set Contrast
Hold + 4 = Frequency counter mode (Use rotary knob to change bands)
Hold + 5 = USB PORT TEST
Hold + 6 = Key / screen test - shows on the screen which keys are pressed.
Hold + 7 = Load Test Data - search bank 6
Hold + 8 = Load Test Data - search bank 6
Hold + 9 = Load Test Data - search bank 9
Scan + 1 = Frequency counter mode (Use rotary knob to change bands)
Srch + 1 = Load Test Data - search bank 6
Scan + 3 = Key / screen test - shows on the screen which keys are pressed.
Scan + 4 = Load Test Data - search bank 1
Scan + 7 = Load Test Data - search bank 7
Scan + 8 = Load Test Data - search bank 7
Scan + 9 = Load Test Data - search bank 0
Scan + 0 = Load Test Data - CH401 - 404 / Adjust Voltage
Srch + any number key = Load Test Data
L/O + 5 = Load test Data - search bank 1
L/O + 6 = Turn on LCD backlight (remove batteries to turn off)
L/O + 7 = Load test Data - scan bank 1
L/O + 8 = Load test Data - scan bank 1
E + 1 = Factory Reset / Country Mode Australia
E + 2 = Factory Reset / Country Mode New Zealand
Launceston Radio Scanning: UBC126AT Key Press Codes
