Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
  #21 (permalink)
Old Today, 3:27 PM
UPMan's Avatar
Uniden Representative
Ideally you would inject two signals. One to provide a solid "floor" then slowly increase the 2nd frequency (in the same band) until it triggers. Close call triggers when a signal is a certain dB above either the noise floor or the strongest other signal in the band. In the real world, since an antenna can affect signal amplitude, an external antenna can affect close call range. One example from my experience is that I've never gotten a CC hit from an aircraft on an on-unit antenna but have gotten many on an external antenna. The antenna raised the target signal level much more than it raised the noise floor.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #22 (permalink)
Old Today, 3:32 PM
KevinC's Avatar
Moderator
And if my radio didn't have this design flaw I would have never needed to know that information.
Someone told me signatures are silly, so I got rid of mine.
  #23 (permalink)
Old Today, 5:41 PM
KevinC's Avatar
Moderator
Bottom line is the missing cap C1/noise issue is a major issue and not "way overblown" as someone else stated.
  #24 (permalink)
Old Today, 7:17 PM
pdfdems286's Avatar
Ok, I have a question. When my batteries were in the 436, I did not have a clock issue. I removed them, and stored away the radio, for about a month. When I repowered, I had lost the date/clock. Is this normal, if you have c1 installed ?.
Scanning drive's me to & save's me from insanity !
  #25 (permalink)
Old Today, 7:21 PM
jonwienke's Avatar
That is totally normal. The tiny RTC backup battery only lasts a week or two if the main batteries are removed.
C1 has nothing to do with the clock, other than being on the same circuit board.
  #26 (permalink)
Old Today, 7:24 PM
jonwienke's Avatar
For Close Call hits, yes. For regular reception, not so much, as long as the antenna is physically separated from the battery compartment.
  #27 (permalink)
Old Today, 7:42 PM
KevinC's Avatar
Moderator
How silly of me, everyone should use one of these when going portable then...
http://mizzoumagarchives.missouri.ed...ennas-is-2.jpg
Or for simulcast this one...
https://forums.radioreference.com/at...helmetyagi.jpg
  #28 (permalink)
Old Today, 7:46 PM
jonwienke's Avatar
A Diamond RH77CA with the Uniden SMA-BNC adapter is sufficient, but you be you.
  #29 (permalink)
Old Today, 7:50 PM
KevinC's Avatar
Moderator
No Jon it isn't. I've done extensive testing on this. What would be sufficient would be if Uniden admitted that this is an issue.
And even if it did it would do "Zip. Zilch. Nada" for Close Call.
But you be you and keep defending Uniden no matter what.
  #30 (permalink)
Old Today, 7:57 PM
KevinC's Avatar
Moderator
In the words of UPMan...
When there is a problem, admit it as soon as possible.
Customers are not stupid. Ignoring or denying a legitimate problem is not the way to handle it.
If necessary, check with legal or senior management before commenting.
Never promise a fix you cannot deliver.
http://info.uniden.com/twiki/pub/publish/upman.html
  #31 (permalink)
Old Today, 8:45 PM
a29zuk's Avatar
LOL!
  #32 (permalink)
Old Today, 8:55 PM
KevinC's Avatar
Moderator
Anyway, I've proven my point so I'm done here.
Thanks for playing along everyone.
