Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
Old 05-13-2018, 6:09 PM
KevinC's Avatar
Moderator
Default BCD325P2 vs BCD436HP Close Call
I didn't want to put this in the Uniden Technical forum because I'm sure many people will let me know how my testing is flawed and useless.
Anyway, made a 285 mile trip last week and had both the 325 and 436 on the same antenna setup (800 3dB antenna and a dual-band 150/460 antenna into a Comet diplexer into a Stridsberg MCA204M, using identical jumpers) searching the same range (460-465) with CC DND activated.
On VHF (air and LMR) it was pretty much a dead heat, with both radios either getting the CC hit at the same time or within milliseconds of each other, UHF was completely different. The 436 would hardly ever get the same CC hits as the 325, it would remain silent most of the time.
On the return trip I swapped the jumpers and had the same results (436 was usually silent on UHF).
Interestingly, with the UHF limit search they would both receive the same weak signals.
Someone told me signatures are silly, so I got rid of mine.
Old 05-13-2018, 6:50 PM
Does your 436 lack the infamous capacitor?��
Old 05-13-2018, 6:54 PM
KevinC's Avatar
Moderator
Yes it does. But you'd think that would show up on a limit search as well, plus I'm using external antennas.
Old 05-13-2018, 8:05 PM
jonwienke's Avatar
IMO it's probably related to C1 missing. The frequency counter chip used for Close Call may be near the noise source on the board. My 436 doesn't have a noticeable difference in close call sensitivity between UHF and VHF, but it has C1 installed.
Old 05-15-2018, 11:37 AM
+1 .
Old 05-15-2018, 2:40 PM
KevinC's Avatar
Moderator
Could be, but I guess I'll never know unless Uniden admits this is an issue and agrees to install it for free.
And if this is it all the people saying to just use an external antenna or just a SMA-to-BNC adapter (for a radio mounted antenna) to minimize the impact need to add the caveat that CC on UHF will still be almost useless.
Old 05-15-2018, 3:27 PM
jonwienke's Avatar
Installing the capacitor takes about 10 minutes if you have one and some SMD soldering skills.
Old 05-15-2018, 3:38 PM
KevinC's Avatar
Moderator
So I'm expected to correct Uniden's design flaw?
Old 05-15-2018, 3:39 PM
milcom_chaser's Avatar
Send it to John...
Old 05-15-2018, 3:42 PM
KevinC's Avatar
Moderator
Originally Posted by milcom_chaser View Post
Send it to John...
I didn't know he did Uniden warranty work. That's good info to have.
Old 05-15-2018, 4:25 PM
jonwienke's Avatar
I install C1, usually while I have the scanner apart already doing GPS or battery mods. But I am not a Uniden authorized warranty repair provider.
Old 05-15-2018, 9:39 PM
My 436 was repaired early in the campaign and was missing C1. I sent it in describing poor receive in the 450mhz range. They billed my credit card when the unit was received. It was repaired with the comment F12J complete. They refunded my credit card and paid return shipping. I thought that was great. The original repair was January 2016. This repair was April 2018.
Old 05-15-2018, 10:16 PM
I keep forgetting I live very close to Jon Wienke, well, both Jon Wienkes, actually... one of these days I'll head over yonder and have the one Jon install C1 and the other Jon show me how to make a custom hearing protection device for my 191... eh, never mind.
Old 05-15-2018, 10:43 PM
pinballwiz86's Avatar
Thanks for posting your observations. I will run my own tests between a BCD436HP, BCD396XT, and BC125AT in VHF/UHF analog transmissions, and between the two digital scanners on digital P25.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 05-16-2018, 9:29 AM
bravo14's Avatar
How can I tell if I am missing C1 without opening the radio? When I send the radio in for the RTC problem.
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP HomePatrol-1
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
Old 05-16-2018, 9:32 AM
jonwienke's Avatar
If your radio has the RTC or display issues, it definitely doesn't have C1, because that version of the board doesn't have the pads to install C1.
Old 05-16-2018, 9:37 AM
bravo14's Avatar
So far after I turn them in for RTC over a year ago I had no problems with display or RTC problems.
Old 05-16-2018, 9:45 AM
jonwienke's Avatar
If you have had the RTC repair done, your scanner probably has C1, unless the repair was done in the first few months of the repair campaign.
Old 05-16-2018, 9:54 AM
bravo14's Avatar
Okay thanks. I think I done that the first week or second week when they had the repair campaign. I do still have use to the cooper tape on the door on the 436.
