Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
Closed Thread
  #81 (permalink)
Old 06-11-2018, 8:35 PM
I was pleasantly surprised to see the yellow piece of paper notifying me that the battery was not going to meet expectations and that Uniden is on top of it. KUDOS again to Paul and the SDS100 team!
  #82 (permalink)
Old 06-11-2018, 9:14 PM
Agreed, you dont see that much, if any.
Sent from my iPad using Tapatalk Pro
Uniden SDS100
Uniden Home Patrol-2's W/ Extreme Upgrade
  #83 (permalink)
Old 06-19-2018, 10:44 AM
WoodburyMan's Avatar
Great move! Registered my SDS100 yesterday when I got it from HRO. Looking forward to the new battery and door!
When I opened my SDS100 I had a small issue too, the nob at the top would not rotate, it got banged up in shipping or something. I needed to force/bend it slightly back into shape now it rotates normally.
  #84 (permalink)
Old 06-21-2018, 1:40 AM
While the battery situation is not ideal from the inception, an indication of “something not right with Uniden” would be ignoring it and not doing anything to address it.
Instead they are doing the right thing and going back to correct an issue they identified once the units went to production. This is no minor response. Not only are they providing replacement batteries, they are making modifications to the battery cover housing.
There are definitely other examples of quality issues. I can say that, being someone who worked for many manufacturers over the years, this is not one of them.
Sent from my iPhone using Tapatalk Pro
  #85 (permalink)
Old 08-01-2018, 9:18 AM
Months passed, we have August now. Upman, any news?
  #86 (permalink)
Old 08-01-2018, 9:25 AM
Check post #1 in this thread.....
"Around August".
  #87 (permalink)
Old 08-01-2018, 9:30 AM
mule1075's Avatar
Reread post #1 in this thread.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
  #88 (permalink)
Old 08-01-2018, 5:29 PM
Doesn't play well with others
Howto tel if my sds100 came with battery upgraded? Battery cover seems to be same thickness and smoothly fits and is not raised or out at ell... i also love the clip that holds the battery cover in place
  #89 (permalink)
Old 08-01-2018, 5:33 PM
I heard the bigger battery will have a battery cover that is not flush with scanner and has a noticeable lip.
  #90 (permalink)
Old 08-01-2018, 5:34 PM
jonwienke's Avatar
Look for the note in your scanner box...
Gone camping.
  #91 (permalink)
Old 08-01-2018, 9:02 PM
My mistake... Right to the toys and not look at the paperwork... Thanks a bunch... It had the slip of paper and already registered and got my 3 keys...
  #92 (permalink)
Old 08-04-2018, 9:59 AM
Along with the new extended battery coming out this month, I would like the opportunity to purchase a second original thin battery for my SDS100. I like the idea of having the option to accessorize my scanner with the thin or extended battery based on how I will use my scanner that day. Some days I might just need the scanner for a few hours or carry in my pocket and some days I will need two extended batteries to get the job done. Two thin batteries and two extended batteries with an external charger would be my preferred power package for the SDS100.
  #93 (permalink)
Old 08-04-2018, 11:48 AM
bob-k's Avatar
When I get the new one I am hoping I can charge the new and old one externally I will use the current one as a back up! I will keep both bottom panels
4 oldies, Plectron, RS Pro-96 & Uniden SDS100
Support those who serve us actively or in the past! US Military, Veterans, all LEOs, FD, EMS & Emergency Management!
I'm a Navy Vet, I got your 6!
  #94 (permalink)
Old 08-09-2018, 12:54 PM
trido's Avatar
can today confirm sds 100 shipping with larger 5400 maH battery<Name:  bat.jpg
Jeff
  #95 (permalink)
Old 08-09-2018, 1:16 PM
del1964's Avatar
Sweet
http://www.broadcastify.com/listen/feed/3666
Uniden BCD396XT, Home Patrol II, WHISTLER TRX-1, AIRSPY, RTL-SDR, Unitrunker, DSD+, SDS-100, sdrtrunk v0.3.4-beta.2
  #96 (permalink)
Old 08-09-2018, 1:32 PM
Neat!! Wonder when they'll start the roll out campaign to existing users. Do you have any pictures with it attached to the radio?
Erik, KC1IUC
Scanners: Uniden HP II, SDS100
Radios: TYT: MD-380, MD-UV380 GPS Anytone: AT-D868UV Kenwood: TH-74A BTech: 5x3
  #97 (permalink)
Old 08-09-2018, 5:00 PM
I plug my scanner in every night after i use it that day, so its fully charged for the next day, and it has gone dead on me a few times, and the cables i have in the car neve work, always get low voltage error, so i can never listen to it anymore till i recharge it at home. Look forward to getting the new battery and door, sure would be nice to have it designed for a drop in charger rather than plugging it in, just an idea
Uniden SDS100
  #98 (permalink)
Old 08-09-2018, 5:08 PM
Originally Posted by trido View Post
can today confirm sds 100 shipping with larger 5400 maH battery<Attachment 65323
Yes, pictures of the back of the radio with new battery door installed, please.
  #99 (permalink)
Old 08-09-2018, 5:33 PM
bob-k's Avatar
Default Did you know
Tx, you can plug in to charge and plug into upper USB to run simultaneously sir. Because I run with an external GPS so its best for me running two inputs!
  #100 (permalink)
Old 08-10-2018, 1:12 PM
trido's Avatar
Well it sure wont TILT over very easy.
Jeff
Closed Thread
Tags
sticky
