Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
  #61 (permalink)
Old 09-26-2018, 7:54 PM
This is the second copy of the radio. The first one has poor sensitivity especially noted on VHF-UHF. Second copy works much better. Performance on the Centre County, PA system, the Washington County, MD system and the Dauphin and York County, PA systems is more than decent. It seemed to work well on a short visit to the Phase II PG County, MD system (with the North and South programmed as separate favorites) The only major problem that I've noticed is the fact that the radio does not stop on certain talkgroups although when manually dialed into those groups reception is just fine.
Question: Is there a location to learn manual programming on the "fly.?" Also, how to program an "open" bank, essentially to monitor all traffic on a system? Thanks!
  #62 (permalink)
Old 09-26-2018, 8:34 PM
hiegtx's Avatar
Mentor
For programming steps, probably your best first step is on the Easier to Read Manuals site. Look at the link for 436HP/536HP Sentinel version. Other than the added options for display on the SDS100, and the NAC field entry for trunked systems, programming is pretty much the same for all of these scanners. If you are missing certain talkgroups, are the service types enabled? And, if using location control, are the MIA TGIDs in their own manually created department? or in a department with other IDs that are normally received without issue?
There is no "open bank" option on the DMA scanners. Open bank was what was used on the older Radio Shack scanners, such as the Pro-97 or Pro-96/-2096. For the Uniden scanners, if you want to hear all active talkgroups on the system, then set the system to "ID Search" instead of "ID Scan".
ID Search will stop on any active talkgroup it finds, except for TGIDs that have been locked out (avoided) or that are in a Department that has been set to Avoid. If the ID is programmed, then you'd see the TGID as well as the text tag programmed. If active (and not locked out as noted), but not programmed, then you'd see only the TGID when the scanner stops on it. If the ID was programmed, but it's Service Type was not enabled, it would also be skipped, regardless of whether ofr not set to 'Avoid'.
ID Scan will scan only the TGIDs that are programmed in the system on the scanner, that are not avoided, and are not in a Department that has been avoided. As above, the Service Type would need to be enabled, regardless of Avoid status.
Steve
SDS100-436HP (2)-536HP-TRX-1-325P2-among others
  #63 (permalink)
Old 09-26-2018, 10:42 PM
rbrtklamp2's Avatar
What do you mean by second copy of the radio? Are you saying the first batch was tainted and that's why some of us are having difficulties with V/UHF? If so I would think this maybe something Uniden would set up a repair campaign for as both of my SDS100s seem to suffer on the UHF and VHF bands. Thanks in advance for any insight into your statement of the second copy of the radio.
Sent from my SM-N960U using Tapatalk
Stop streaming public safety comms before encryption kills our hobby!
  #64 (permalink)
Old 09-28-2018, 12:47 PM
To rbrtklamp2,
The first radio had a sensitivity on VHF and UHF of (estimated 5mv). It worked on the local Phase 1 system but with 9 sites I could pick it up on a paperclip. Since my service monitor remains pack away following relocation I estimated sensitivity based on reception of WX radio, Amateur repeaters (both bands) with comparisons to known radios. My second radio (or copy) seems to perform similar to a Radio Shack PRO 96. Good enough for general use but not so sensitive as to be prone to overload (front end saturation.) BTW. The folks at Scannermaster made the trade-out painless. A positive business experience.
  #65 (permalink)
Old 10-09-2018, 9:36 PM
I live in western Washington state. Our area is heavy in P25 Phase II. I have a BCD436HP and the reception varies from site to site with some distortion in most transmissions. I have not seen any comparisons between the SDS 100 and the 436 in Phase II. Help?
  #66 (permalink)
Old 10-09-2018, 9:56 PM
Citywide173's Avatar
You could make a Google form that would or would not require login. The form would then link to the spreadsheet. It would be a different layout, as each row would be for a specific system, but you could put formulas in to average out the overall numbers and have each system with averages display in its own tab. It would mean starting from scratch. I'd be more than happy to design the form and speadsheet if you like.
Ed Burke
KD1EMS WQRD823
Administrator: Firepics-THE Place for fire photographers
Tags
sticky
