Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
Old 07-12-2018, 7:58 AM
Default Need a amplified speaker for my sds100
For some reason any volume past 8-15 doesn't sound any different on my sds 100. I have volume offset set to +3 on all channels. Can anyone recommend a cheap but really good sound quality speaker. Not sure if this the correct place to post this if not please correct it.
Sent from my SM-G965U using Tapatalk
Old 07-12-2018, 8:25 AM
jonwienke's Avatar
The second sentence explains the first. Volume offset doesn't make the maximum volume any louder. Maximum volume setting is still 15. Setting a volume offset on every channel is pointless--it just means you reach maximum volume before you have the volume turned up all the way. With a +3 offset, there is no difference in speaker loudness between volume settings 12 and 15.
You can find decent speakers for cheap, but not really good ones. Computer speakers work pretty well.
Gone camping.
Old 07-12-2018, 8:47 AM
I use a bose portable speaker. It's good.
Hi sir i messaged you the other day regarding the GPS cable. I didn't get a reply back. Can you check your messages please. Thank you.
Old 07-12-2018, 8:53 AM
jonwienke's Avatar
If this is directed to me, the last PM I got from you was regarding a BNC adapter. My direct email is jonwienke@gmail.com.
Gone camping.
Old 07-12-2018, 11:01 AM
Sorry that's directed to the op. I was asking him about the GPS cable. I'm sorry Jon.
Old 07-12-2018, 11:03 AM
jonwienke's Avatar
No worries.
Gone camping.
Old 07-12-2018, 11:04 AM
Jon I tried to edit the post and there's no option to edit it.
Old 07-12-2018, 12:53 PM
rwier's Avatar
I have had success using 12 volt powered speakers, from both RadioShack and Uniden. At one time, I had four mounted in the 4 corners of my Dodge Ram. I have custom tail pipes, and scanners just can't compete with that wonderful sound from the Hemi, lol.
Rob, Phoenix, AZ since '40
Unication G5(VHF), 996T, 396XT, 996XT, HP-1E (x3), 436HP, 536HP, 500, 600, and 800 (x2)
Old 07-12-2018, 1:28 PM
n2pqq's Avatar
You can get one of these for $15.00 on Ebay or $20.00 on Amazon.
Phillips BT2500B
https://www.amazon.com/Philips-BT250.../dp/B00J3O9YRY
You will also need a audio cable from speaker to radio .
https://www.cnet.com/products/philip...peaker/review/
Should fit all your needs .
Old 07-12-2018, 1:48 PM
Check your inbox now.
Old 07-12-2018, 1:50 PM
Phillips BT2500B
How do I know if this speaker is amplified or not? The one from amazon
Old 07-12-2018, 1:53 PM
iMONITOR's Avatar
UNIDEN BC23A 'amplified' speaker (requires 12VDC)
Old 07-12-2018, 2:01 PM
So should I disable volume offset or lower it?
Old 07-12-2018, 2:11 PM
jonwienke's Avatar
I would get rid of it. It won't do what you want it to do (increase maximum volume), and it reduces the total number of volume levels you can set with the knob (13 vs 16).
Gone camping.
Old 07-12-2018, 2:53 PM
n2pqq's Avatar
https://www.download.p4c.philips.com...00_dfu_aen.pdf
Page 9
Old 07-12-2018, 3:10 PM
What's the difference between amplified vs a normal speaker as far as scanners are concerned?
Old 07-12-2018, 3:16 PM
jonwienke's Avatar
If you're running the speaker off a headphone jack, an amplified speaker is required.
Gone camping.
Old 07-12-2018, 3:37 PM
Talking SDS100 Amplified Speakers
When using the SDS100 in my vehicle, I run a standard audio patch cord from the scanner headphone jack to the AUX input on my vehicle sound system. Not only can I control VOLUME, but also the EQUALIZATION for best sound quality and clarity. Works great for me!!
