  #201 (permalink)
Old 03-20-2013, 8:47 PM
troshs's Avatar
Dont know if this has been mentioned before, or if its already available, but the ability to record and store voice right on the unit. I know you can send it to a peripheral device, but some of the Minitor 2 pagers out there have the option to store voice. Something like that would be pretty awesome.
  #202 (permalink)
Old 03-20-2013, 9:27 PM
Default What Do You Want In The Next Uniden?
That already exists in the HP1.
  #203 (permalink)
Old 03-21-2013, 4:13 AM
pb_lonny's Avatar
Whatever it is, all I want is for it to be released in Australia....
  #204 (permalink)
Old 05-18-2013, 5:48 PM
I would pay maybe $200 for Uniden if they made user-friendly scanner software that could work with any number of SDR modules.
  #205 (permalink)
Old 05-18-2013, 6:12 PM
wv_mountaineer's Avatar
Location: In a house along a busy road in Mercer County, Farrell, Pa.
Default my 2 cents
- NXDN
- MOTOTRBO
- P25 Phase II TDMA and P25 X2-TDMA
All of the local PD's in my county are switching over to NXDN and the Railroad will also be doing so sometime in the next 5 years.
Scott in Mercer County Pa.
Uniden BCD-396XT & BCD-996XT, GRE PRS-300, Radio Shack Pro 164, Pro 97, Pro 51
My Mercer County, Pa. Live Feed: http://www.radioreference.com/apps/audio/?feedId=5084
  #206 (permalink)
Old 05-18-2013, 6:29 PM
mg5555's Avatar
Cat 5 or 6 so you can stream it over your home network. Perhaps have in your shack and listen to it anywhere home or even over the internet. While we are at it remote programming as well. Bluetooth audio streaming as well.
"Once you get over the Hill......you pick up speed"
  #207 (permalink)
Old 05-18-2013, 8:31 PM
davidmc36's Avatar
I'll call it "Adaptive Priority"
Every system is rated from 1, 2, 3, ...... to however many system you have. If system 1 is active it gets scanned. If activity slows down then it starts scanning system 2 also. If they are quiet it adds system 3 to the scan, and so on. You never have dead air but your favorite system always gets priority.
No Bounce, No Play.
The one who dies with the most toys wins.
Even though hydrogen is the most abundant element in the universe, stupidity is a close second.
  #208 (permalink)
Old 05-18-2013, 8:33 PM
to me this is looking more interesting everyday
Alianza DXB ::: Smartphone Docking Walkie-Talkie
Stephen Charlton canadawalrus@gmail.com
BCD-396XT, CDM-1550LS, M Spectra, Tyt-9800, UV-5R x3, Wouxun UVDP1 ? x 3,, UV-B6, BF-666, Midland GMRS Base Radio,GMRS Radio x 2, 1x Md380, RCI-2950
  #209 (permalink)
Old 05-18-2013, 8:39 PM
Full Police Encryption Decoding !
  #210 (permalink)
Old 05-18-2013, 8:51 PM
A newer version of the 396XT / 996XT that has some of the HP-1 features like GPS rectangles, unlimited TGIDs per trunked system, and unlimited groups in both conventional and trunked systems. Also maybe a 20 character alpha display. And of course P25-Phase II TDMA.
  #211 (permalink)
Old 05-18-2013, 9:30 PM
cherubim's Avatar
It would be good if Uniden did the following in a newer scanner:
* Implement fast and effective subtone decoding
* Include support for more than 500 Talkgroups per trunked system
* Implement a digital AGC that works - the current one is a joke
* Implement a display that uses space more efficiently and has better legibility from all angles
* Get rid of that archaic serial port interface and use a micro usb port instead
* Increase memory capacity
* P25 Phase II TDMA support would be nice
  #212 (permalink)
Old 05-18-2013, 10:41 PM
I wouldn't mind seeing a "sleep timer" that would shut the scanner off after a selected period of time.
  #213 (permalink)
Old 05-18-2013, 10:45 PM
THERE already is, after about 10 hours the batteries die and the scanner turns off
  #214 (permalink)
Old 05-18-2013, 11:11 PM
skidplate's Avatar
A 10 Mhz IF tap
Skidplate
  #215 (permalink)
Old 05-19-2013, 6:10 AM
I travel in an area with multiple SmartZone sites. If I hear an event happening on Talk Group 1 and coming from Site A, I hold on it to hear what is going on, but the hold only works for that T G on that site. I would like to be able to hold on a T G but the scanner will move on to other sites as I travel along. The way it is now with the scanner on hold I really have no idea if and when I have moved out of range and need to start scanning again in the hopes of getting that same T G from the next site I come in range of.
Radio monitoring and scanning since the 60's. VE1CY. Former manager of CZDE.
  #216 (permalink)
Old 05-19-2013, 10:22 AM
jkahn's Avatar
Originally Posted by RadioDitch View Post
Hoping this thread doesn't get shot down. Because I think UPman and several others have made it clear our input counts. As a customer, I'm frustrated that there are some things missing that could make Uniden, my favorite brand, the ultimate.
Here's my *wish list* for whatever is next...
***P25 Phase II TDMA Capable (A reality only 6mos out for us in NJ)***
-NXDN Capable (Railroads WILL be switching over in 2017. Railfans are a big part of your market guys!)
-P25 Standard Non-TRS Radio ID's (Single channel trunked for this is a major pain)
-MDC ID Decode
-Ability to enable iCall in radio menu, without FreeScan
-Detachable faceplate WITH power control would be awesome for mobile ops. (BC-RH96 is bulky for this, and has no power control.)
P25 Phase II TDMA and P25 X2-TDMA are really as simple as a Firmware Update. As a loyal customer, I think it should be a big priority.
So what would you like to see??
I would like all of these things, but since my HP-1 runs all day on my office desk, I would really like to see a Keurig type coffee maker built in, so I would not have to leave the desk except to pee.
FYI: It has been stated many times by Upman (who should know) that Phase II/TDMA requires a change to the hardware as well as firmware. Really....don't you think if it could be added by just firmware that they would have done that already?
JK
JRKahn
Uniden HP-2 Extreme; Uniden HP-1 Extreme; BCD436HP(DMR); 996T; 250D; & a multitude of unused older Unidens, some with crystals! .....and a GRE PSR-800 (that thinks its a W-1080 with DMR) !
  #217 (permalink)
Old 05-19-2013, 9:09 PM
#1. NXDN
#2. an easier to read s-meter.
  #218 (permalink)
Old 05-19-2013, 9:54 PM
szron's Avatar
Most probably were mentioned already
1) TRBO (don't bull**** me, it's possible, the standard is open)
2) P25 both Phase II and X2 (same as above)
3) MDC decode with Alpha tagging
4) Radio IDs with Alpha tagging
5) Factory discriminator output
6) True site roaming
7) Timed lockout for nuisance channels during a major incident
All of above can be put in <$1000 scanner. It's a matter of somebody wanting to do that.
Station 20
  #219 (permalink)
Old 05-20-2013, 3:04 AM
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
I don't know how the Unidens do it, but on my PSR-500, when I'm scanning a trunked system, I don't need to know what voice channel I'm receiving a transmission on. Make it at least an option, to put alpha-tagging in that line, in place of the frequency.
  #220 (permalink)
Old 05-20-2013, 3:07 AM
More LTR support Passport capabilty
