  #121 (permalink)
Old 03-20-2014, 10:29 PM
Anvil's Avatar
I connected the 536 to my Dell Venue Pro 8 which is running Win 8.1 Pro using the StarTech adapter I mentioned earlier with FTDI chipset and it's running fine with the ARC536PRO beta. It didn't even ask for a driver.
  #122 (permalink)
Old 03-20-2014, 11:41 PM
davenlr's Avatar
Ok, thanks much for that info. Think Ill order one.
Scanners: BCD536HP BCD436HP BCT15
Ham: HTX-212 Yaesu 757 Kenwood B2000
  #123 (permalink)
Old 03-21-2014, 7:12 AM
WaveJam's Avatar
Originally Posted by UPMan View Post
2. Until we can determine what conditions result in the scanner rebooting under USB Serial mode, this is the best solution. It can take from hours to days for the symptom to occur, and no one has yet isolated a specific, reliable way to duplicate the issue. That kind of bug can be extremely difficult (and time consuming) to track down.
Paul, I wish you could track down my original scanner which I sent back to you a couple weeks ago. I think it would be a great test specimen as this problem occurred very regularly. It was S/N 375Z38002103.
Sincerely,
Pete
www.frederickscanner.com
  #124 (permalink)
Old 03-21-2014, 3:40 PM
Originally Posted by davenlr View Post
Are you using Windows 8.1? The prolific drivers wont work on 8.1, so I was hoping to find another chipset that will, since I have a card coming, but really dont want to use my last slot in the computer for it.
Actually, they do work with windows 8.1. It probably has more to do with the discrete components that make up a specific computer. The prolific drivers fixed the problem I was having with my Surface Pro 2.
  #125 (permalink)
Old 01-22-2015, 1:43 AM
im running into to this usb issue on my new unit as well very frustrating
SN: 375Z48006XXX
