Every Time I turn on either unit I end up having to re-program the clock and day/month etc.
Any Help would be appreciated.
I am having the clock reset problem with the BCD436HP. Virtually every time I turn on the radio, I need to reset the date/time. I have upgraded to the latest firmware. Any suggestions?
i am having the clock reset problem with the bcd436hp. Virtually every time i turn on the radio, i need to reset the date/time. I have upgraded to the latest firmware. Any suggestions?
I had the same issue when I first powered the unit. It happened 3-4 times but since then, it never asked me for the time etc.
I also plug in the USB and say no to charge.
So, what nobs do I twiddle or buttons do I push in order to run the
436HP from the USB power supply?
teknishun KF5OPQ
2) Leave the scanner turned on w/power for a long time to charge the internal battery (they clock does not run off of the AA's).
