Old 04-13-2014, 1:45 AM
Default HP-1 "SD Card" error - any ideas?
My HP-1 will not boot. It briefly flashes "Homepatrol-1" on the screen then displays the SD Card Error message. Tried different cards with no luck. When connected to the computer via USB the card shows up fine - reads/writes/etc. but Sentinel will not see the scanner. Tried the reset button - no change.
Any other ideas?
Old 04-13-2014, 1:55 AM
Nevermind - figured it out. Mods - you may delete this thread.
Old 04-13-2014, 7:05 AM
dmg1969's Avatar
Just a suggestion. When you come back and post that you found the solution or figured it out...you may want to say how you fixed it. That could help others out and not necessitate them starting their own thread.
I get that on occasion with my HP-1. Generally unplugging the power for 15-30 seconds does the trick. Only once did I have to reseat the SD card.
Dave
My Scanners: HP-1, BC125AT, BC355N and Baofeng UV-5R2
Founder Perry County Pennsylvania Scanner Enthusiasts Group on Facebook
https://www.facebook.com/groups/407409399385884/
Old 04-13-2014, 11:37 AM
It wasn't a big deal. When I launched sentinel to reinitialize the card I didn't check the "show all drives" box so Sentinel didn't show it. When I did that I could see the HP-1 card and install the software.
Old 04-13-2014, 11:18 PM
Was k2ool/k1nng
Another thing to look for on my Hp-1,the sd card would sometimes find its way under the sd card slot ,sneaky little guy he was.Looked like it was in,but no.
