Old 05-05-2014, 5:15 PM
Unhappy Not picking up channels now
I have a Uniden BCT15-X that I really like using. It is hooked up in my car and was working great. Last weekend a friend was riding with me and she put her arm against it (between the seats), it beeped a couple of times and now won't pick up channels, I completely reset it and programmed all the frequencies back into it like before. For some reason now, it will just scan and not pick anything up. I definitely checked all the wires and antenna to make sure nothing got damaged. Am I missing something? It seems to still have the latest firmware as well (1.03). Thank you in advance for any help you can provide.
Old 05-05-2014, 5:18 PM
Maybe the Global Attenuator was turned on??
Suggest you try to perform a Weather scan or program a FM broadcast station that is close to see if you can receive anything.
Once you know you can receive a Weather channel or FM station, then move on from there.
Old 05-05-2014, 6:32 PM
The global attenuator is turned off and I am still not receiving The Weather Channel
Old 05-05-2014, 7:23 PM
eyes00only's Avatar
Check the antenna pin to be sure it's not broken.
JK
"There is a fine line between 'hobby' and 'mental illness'."
Old 05-06-2014, 8:21 AM
n4yek's Avatar
Try removing your coax from the scanner and just push a coat hanger into the center of the connector.
If you start receiving again, the coax connector is shorting out from your antenna.
Just a thought.
Danny
A blood donor saved my life (Matthew 26:28)
If 'con' is opposite of 'pro', is Congress the opposite of progress?
Old 05-06-2014, 10:43 AM
LIScanner101's Avatar
I'm going with the antenna/BNC on this one also. When you said you checked the wires and the antenna, exactly what do you mean? Do you have another spare antenna you can try, preferrably a duck type so there is no coax involved?
Base/Mobile Scanners: Uniden BCD996XT, Radio Shack PRO-163
Attic Antennas: Monitenna 5094A, A/S MONR31, MON-58
Mobile Antennas: A/S MONR33, MON-52
Old 05-06-2014, 5:29 PM
I tried 2 other antennas and still nothing..not even the weather is being picked up. Seems wierd. I don't know if this makes any difference either but I program manually as I have a MAC so its not easy to find software for me. The fact that I can't even get weather is really odd. I have all the same stuff programmed in my BC346XTC and it works just fine.
Old 05-06-2014, 6:00 PM
Take the cover off and check to see if the BNC RF wire got disconnected from the BNC jack.
Old 05-06-2014, 6:30 PM
Try looking at your Firmware. You may need a update!
Old 05-06-2014, 6:45 PM
My Firmware is 1.03 which is what it says is the latest for this scanner. Is there newer firmware I'm missing?
Bill W. (no not the man who created AA)
BCT15X BC346XTC AustinSpectra Antenna
I assume it's fairly easy to remove the cover?
Old 05-06-2014, 7:44 PM
Uniden BCT15 Firmware Revision Notes 1.06.00
Old 05-06-2014, 8:06 PM
I had same version and wasn't picking anything up, same as you. I did the Firmware update and it seem to help. Downloads - Product Information at Uniden
Hope this helps!!!
Brian
Old 05-06-2014, 8:29 PM
Default static zap
Was it an exceptionally cold, dry day? Sounds like an rf stage got blown! In which case, your radio might be today!
Old 05-06-2014, 8:30 PM
I meant 'toast' (auto text sux).
Old 05-06-2014, 8:38 PM
Please don't tell me that. No it really wasn't cold at all.
Old 05-06-2014, 8:40 PM
I was told that the BCT15X is not the same as BCT15..but I'm willing to give it a shot.
Old 05-06-2014, 8:51 PM
hiegtx's Avatar
Mentor
The firmware for the BCT15X & BCT15 are not interchangeable.
The most version for the BCT15X is 1.03.00, which is what you said you have.
Steve
Old 05-06-2014, 11:17 PM
Default Now what?
, it seems that it would be very difficult to take the scanner apart.. I'm not sure where to go from here
Old 05-07-2014, 1:19 AM
Default Now what?
I took the case off and it looks like there's like eight more screws that I need to take out to take the whole thing apart. Is that correct?
