Old 05-12-2014, 5:33 PM
KI4LIV's Avatar
Default BR330T - how to find CTCSS or DCS Tone/code?
The radio shop that programmed our radios at work went out of business, and nobody at work has a clue whether our VX-231s use DCS, CTCSS, or nothing at all. We're just trying to find out the configuration of these radios so we can order more!
I've used my BR330T's close call to find the frequencies - so that's a step forward.
I programmed the frequency into a programmable HT that I have - I can receive from the work HTs, but they can't hear me.
I've turned on every available option in Close Call and everywhere else (that I could find) to decode/search for CTCSS or DCS, but where do I find what it's found?
CC doesn't show any tone/code on the screen when it finds the frequency.
Can anyone point me in the right direction?
--Light is faster than sound... Perhaps that explains why some people appear to be intelligent - until we hear them speak!
Old 05-12-2014, 5:45 PM
Kirk's Avatar
DB Admin
Once you've found the frequencies, program them in as standard channels. Remember that if they use a repeater, the transmit and receive frequencies are different. Set the CTCSS option (in the programming menu) to SEARCH.
If nothing is displayed, it's likely carrier squelch (no PL or DPL used). Otherwise, the PL or DPL will be shown.
Old 05-12-2014, 5:53 PM
KI4LIV's Avatar
This is def a simplex only setup, so no repeaters.
I have the frequency saved as a regular freq, and set it to search... when I key the HT should it show the tone/code if it has one?
Old 05-12-2014, 5:59 PM
Kirk's Avatar
DB Admin
Yes. If you have ham rig, you might experiment with it so you know it's working right. (program a simplex ham channel in your ham radio, program the same channel in the scanner in search mode, then transmit using PL, no PL and DPL (if your ham rig has it)).
Old 05-12-2014, 8:51 PM
wtp wtp is online now
CTCSS/DCS Search
CTCSS/DCS Search lets you search for CTCSS or
DCS tones when it finds an active frequency in search
and Close Call modes. You can identify up to 50
CTCSS tones and 104 DCS codes.
menu turn knob to Srch/CloCall Opt ,yes or enter
turn knob to CTCSS/DCS Search, yes or enter.on, yes or enter
Turning this option on lets the scanner search for
CTCSS/DCS tones. If the scanner detects the tone, it
displays the tone’s frequency and DCS code. Select
your setting, then press the scroll control.
On - CTCSS/DCS search is turned on.
Off - CTCSS/DCS search is turned off.
it might be that it is there when they transmit and is gone when the carrier drops.
Old 05-13-2014, 9:02 AM
KI4LIV's Avatar
Originally Posted by wtp View Post
CTCSS/DCS Search
Been there done that :-/ Not finding any CTCSS tones or DCS codes... If it is finding them, it's not displaying them.
Now - that having been said, I did further testing this morning - sure enough, ONE frequency IS using a repeater!
Oddly enough - I searched the FCC frequency database - there's no repeater listed on the frequency, input or output , in this county.
Old 05-13-2014, 11:36 AM
Default duplex
sounds like duplex could be repeater or just conventional duplex for whatever reason.
